1Step 1
Assemble the Frame
A) Cut the Frame Pieces
B) Put the Joists together
C) Tilt the main joists on it's side and attach the first two legs
D) Tilt the frame back up and attach the two legs
E) Repeat the Process for the other half
F) If your vehicle is large (like Goliath) it may not fit in the space between the legs. If so, place the vehicle in the center and place the two halves in position
G) Attach the cross beams to join the two halves together
At this point the stand can be used passively for testing. Depending on the vehicle configuration lines can be connected from above and from the sides to constrain the vehicle
2Step 2
Adding the Thrust Measurement Hardware
Peter McCloud
