New features implemented
05/04/2015 at 19:58 • 0 commentsNew features:
- Ability to configure Access Point ESSID and password from website (/wifi page). If password is set then WPA PSK is used for wifi protection, otherwise network is open
- Ability to configure basic authentication to protect wifi configuration page. If user is black then basic authentication is off.
- Reset setting feature. After hard reset (power off and on) you have 5 sec to connect GPIO2 to GND for 3sec. You cannot set GPIO2 to LOW during booting because ESP will not boot. Normal boot takes 1 sec, after you have time to connect GPIO2 to LOW. You can watch counter on serial/COM output with speed 115200 bps.
pawelka
