Keep your existing Hackaday.io projects up-to-date with your mobile device and this companion app. Capture photos of your hardware projects, caption them, and log your project progress.
How it works
- Take a project photo, crop and rotate if needed.
- Write a caption for your log.
- Select an existing project including private projects.
- Title and create a new log.
- Or choose an existing log to append to.
- Review and post your project update.
Get started
Keeping regular logs of your ongoing hardware projects is the best way to take advantage of the community support and broad visibility provided by the Hackaday.io platform.
Use this app alongside your existing Hackaday.io account. Don’t have an account? Sign up at Hackaday.io.
The app is available for iOS and Android:
Logging in
Your existing Hackaday.io email and password are required to login. If you signed up with Twitter or Github these options are available at the bottom of the login screen.
If you have forgotten your password you can create a new password here.
Photos and editing
On the photo capture screen you can take a new photo or access the photo gallery in the top right. Rotating and crop tools appear after a photo has been captured.
Posting to a project log
Choose from an existing public or private project. Then select from an existing log or create and title a new log. New projects can be created here.
Logging out
From the home screen, click on your avatar in the top right to open the user menu. The menu contains a logout link as well as other options.
Feedback
For general app feedback or questions you can comment below or on the Hackaday.io feedback page.
Richard Hogben
I was looking at how to build an octave per volt circuit for an analog synthesizer. I found an adjustable rectifier with no forward voltage drop. It sits in its own vacuum chamber and can be controlled via feedback using the second diode next to it. They both share the same heat source. They are a glut on the surplus market, so there is yet to be a shortage of the remarkably affordable device. I present to you the Soviet 6H7B (6Х7Б-В) miniature double diode tube. It is soldered into the circuit with its own wires, saving the cost of its own socket that costs more than the tube. The second diode is placed into an adjustable circuit that controls the temperature of their common filament through feedback by measuring the second diodes' throughput. The adjustable feedback of keeping the diodes' common filament at the correct temperature will give its twin the right logarithmic forward voltage. The logarithmic curve of the diode is used by a log amplifier to convert the input of one octave per volt into a linear output some of the other circuity can understand. Keeping the diodes' filament at a much lower voltage and current than its specification sheet says it can handle will keep the tube working much longer, though it may drift in a person's lifetime. The lower Watts should cut back on noise from the tube. If we run out of 6H7Bs, we can switch to any number of other tubes with a common filament and more than one diode. Some company just might start making a 6H7B replacement tube, but they will probably sell them at boutique prices. If someone complains we are glorifying a commie tube, ask them "Then why are there so many on the open market? " I got mine from Ukraine.
So this is basically the last update to the hackaday.io infrastructure? 6 years ago? and full of bot-comments?
I am trying to get serialplot working on a linux pc but have run in to problems. I downloaded the AppImage chmod to executable, and tried to run on Fedora 30. Failed. Couldn't find Qt platform plugin xcb. Adding "export QT_DEBUG_PLUGINS=1" and trying again yielded more info: can't load libqxcb.so: (/lib64/libfontconfig.so.1: undefined symbol: FT_Done_MM_Var)". Tried again on Fedora 27, but failed with "QGtkStyle couldn't resolve GTK." After failing to get serialplot running on Fedora 30 or 27, I am at a loss as to how I should proceed.
You don't need ps2 to uart converter to attach a keyboard, you can directly connect a keyboard micro it requires a timer and an interrupt enabled pin. If you want can help.
Great idea, I'm going to give it a go.
One suggestion: clicking your picture/profile info should open my hackaday profile in browser.
hello
I tried it out and I like it. It's bare bones but it's easy enough to use that I can easily sneak it in my workflow.
Good job with this!
btw the manula has been taken from Antlabs. https://docs.wixstatic.com/ugd/f5a1c8_d40d077cf5c24918bd25b6524f649f11.pdf
For political correctness, please, if you take other poeples files, tell where you have taken them from.
Hi all,
Designing Sci-FI: Interfaces sci-fi / Futuristic Idea Rotary InFlow, Mechanically simple, Total Efficient Systems.
Conceptual Engineering Application, Detail Idea Tip/Technology Submission - State of the Art - Novel InFlow Tech - Featured Project Development; 1-Rotary-Turbo/Gearturbine, 2-One Compression Step/Imploturbocompressor:
Im Individual Inventor, and this is my Work. And I want to show, Here in this Great Site, Great Artist and Designers Platform, as a Conceptual Detail Idea Tip, To Present as New Technology Innovation, and see this Post info, in a way as a view of Designers Platform as a Conceptual idea, for a vehicle Performance System (Work use Application), as a power-plant and propulsion system, in a Novel way, (“Designing Futuristic Sci-FI if you want”). New Kind a Power-Plant, and a new kind a Propulsion to.
(Note; I make this post, as Idea of another different (new one) option, as a power-plant system novel kind. And here Because this concepts, can work to, and different kinds a flows, but I know still a project, And I just want a present in this platform, to show at people were know about atypical engines types, and power-plant and propulsion systems and rotating machinery).
Featured Project Development - State of the Art Novel InFlowTech: ·1-Gearturbine RotaryTurbo, ·2-Imploturbocompressor One CompressionStep: |/ *1; Gearturbine Project, Rotary Turbo, Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD · With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses · 8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type. |/ *2; Imploturbocompressor; Imploducted, One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Imploducted Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature. http://stateoftheartnovelinflowtech.blogspot.mx/
It will surely be better than the Instructables app. Lol. (No sarcasm intended. The Instructables app is terrible.)
It only pulls projects from 2014 till 2017 for me :D the last one is the 433MHz MQTT thing, I presume it's capped somehow?
And after creating and posting a new log, the app crashed. Also the fire emoji was converted to a question mark.
Rocking a Samsung S6 edge, Android 7.0 - cool stuff though!
man this place got spammed o.O this is still a current problem for me
nice idea! It would be nice to be able to add logs without pictures though
Same here. I would also like to be able to start a log with text, and then take a picture after I've started.
@Grant Giesbrecht + 1
+ I would love in this version to be able also create project and start to insert photos in it
I would like have a account on mastodon on hackaday, cell phone ap? no not for me
Nope, not yet.
..hi.... have anyone tried programming a single board esp32 lyra T for a webradio yet ?
Is there a git repository for this? I'd really like to know the secret sauce to integrate photo capture to my Android app!
Whats your Android app?
A solder oven controller, written in Qt so I can debug it on my laptop over serial.
On the phone it uses bluetooth.
It helps to see a picture of the oven on the background so you're using the correct PID settings.
Since it's a phone it would make sense to just snap a picture of a new oven in the app before calibration.
Nice! I've always wanted a Hackaday app and I'm glad to see movement in that direction. I'd love to see a full-fledged app which lets you view and search projects, post comments, edit projects, etc.
Thanks! The current version is purposefully simple to gauge interest and further development.
