Hackaday.io - Capture & Log Mobile App
A project log for Hackaday.io Project
Follow for the 'Hacklet' and latest news about hackaday.io
richard-hogbenRichard Hogben 06/10/2019 at 20:1924 Comments
Keep your existing Hackaday.io projects up-to-date with your mobile device and this companion app. Capture photos of your hardware projects, caption them, and log your project progress.
How it works
Get started
Keeping regular logs of your ongoing hardware projects is the best way to take advantage of the community support and broad visibility provided by the Hackaday.io platform.
Use this app alongside your existing Hackaday.io account. Don’t have an account? Sign up at Hackaday.io.
The app is available for iOS and Android:
Android download link
iPhone download link
Logging in
Your existing Hackaday.io email and password are required to login. If you signed up with Twitter or Github these options are available at the bottom of the login screen.
If you have forgotten your password you can create a new password here.
Photos and editing
On the photo capture screen you can take a new photo or access the photo gallery in the top right. Rotating and crop tools appear after a photo has been captured.
Posting to a project log
Choose from an existing public or private project. Then select from an existing log or create and title a new log. New projects can be created here.
Logging out
From the home screen, click on your avatar in the top right to open the user menu. The menu contains a logout link as well as other options.
Feedback
For general app feedback or questions you can comment below or on the Hackaday.io feedback page.
Roderick Sprague wrote 09/24/2025 at 19:00 point
I was looking at how to build an octave per volt circuit for an analog synthesizer. I found an adjustable rectifier with no forward voltage drop. It sits in its own  vacuum chamber and can be controlled via feedback using the second diode next to it. They both share the same heat source. They are a glut on the surplus market, so there is yet to be a shortage of the remarkably affordable device. I present to you the Soviet 6H7B (6Х7Б-В) miniature double diode tube. It is soldered into the circuit with its own wires, saving the cost of its own socket that costs more than the tube. The second diode is placed into an adjustable circuit that controls the temperature of their common filament through feedback by measuring the second diodes' throughput. The adjustable feedback of keeping the diodes' common filament at the correct temperature will give its twin the right logarithmic forward voltage. The logarithmic curve of the diode is used by a log amplifier to convert the input of one octave per volt into a linear output some of the other circuity can understand. Keeping the diodes' filament at a much lower voltage and current than its specification sheet says it can handle will keep the tube working much longer, though it may drift in a person's lifetime. The lower Watts should cut back on noise from the tube. If we run out of 6H7Bs, we can switch to any number of other tubes with a common filament and more than one diode. Some company just might start making a 6H7B replacement tube, but they will probably sell them at boutique prices. If someone complains we are glorifying a commie tube, ask them "Then why are there so many on the open market? " I got mine from Ukraine.
Tim wrote 08/13/2025 at 12:30 point
So this is basically the last update to the hackaday.io infrastructure? 6 years ago? and full of bot-comments?
john ganci wrote 10/27/2019 at 20:58 point
I am trying to get serialplot working on a linux pc but have run in to problems. I downloaded the AppImage chmod to executable, and tried to run on Fedora 30. Failed. Couldn't find Qt platform plugin xcb. Adding "export QT_DEBUG_PLUGINS=1" and trying again yielded more info: can't load libqxcb.so: (/lib64/libfontconfig.so.1: undefined symbol: FT_Done_MM_Var)". Tried again on Fedora 27, but failed with "QGtkStyle couldn't resolve GTK." After failing to get serialplot running on Fedora 30 or 27, I am at a loss as to how I should proceed.
neelbhai wrote 10/27/2019 at 09:32 point
You don't need ps2 to uart converter to attach a keyboard, you can directly connect a keyboard micro it requires a timer and an interrupt enabled pin. If you want can help.
terryspitz wrote 10/27/2019 at 09:07 point
Great idea, I'm going to give it a go.
One suggestion: clicking your picture/profile info should open my hackaday profile in browser.
matiassimonlesomar2000 wrote 10/13/2019 at 17:24 point
hello
AccidentalRebel wrote 10/10/2019 at 03:04 point
I tried it out and I like it. It's bare bones but it's easy enough to use that I can easily sneak it in my workflow.
Good job with this!
PeterS wrote 10/10/2019 at 01:05 point
btw the manula has been taken from Antlabs. https://docs.wixstatic.com/ugd/f5a1c8_d40d077cf5c24918bd25b6524f649f11.pdf
For political correctness, please, if you take other poeples files, tell where you have taken them from.
PeterS wrote 10/10/2019 at 01:04 point
Hi all,
Carlos Barrera wrote 10/09/2019 at 22:54 point
Designing Sci-FI: Interfaces sci-fi / Futuristic Idea  Rotary InFlow, Mechanically simple, Total Efficient Systems.
Conceptual Engineering Application, Detail Idea Tip/Technology Submission - State of the Art - Novel InFlow Tech - Featured Project Development; 1-Rotary-Turbo/Gearturbine, 2-One Compression Step/Imploturbocompressor:
Im Individual Inventor, and this is my Work. And I want to show, Here in this Great Site, Great Artist and Designers Platform, as a Conceptual Detail Idea Tip, To Present as New Technology Innovation, and see this Post info, in a way as a view of Designers Platform as a Conceptual idea, for a vehicle Performance System (Work use Application), as a power-plant and propulsion system, in a Novel way, (“Designing Futuristic Sci-FI if you want”). New Kind a Power-Plant, and a new kind a Propulsion to.
(Note; I make this post, as Idea of another different (new one) option, as a power-plant system novel kind. And here Because this concepts, can work to, and different kinds a flows, but I know still a project, And I just want a present in this platform, to show at people were know about atypical engines types, and power-plant and propulsion systems and  rotating machinery).
Featured Project Development - State of the Art Novel InFlowTech: ·1-Gearturbine RotaryTurbo, ·2-Imploturbocompressor One CompressionStep: |/ *1; Gearturbine Project, Rotary Turbo, Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD · With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses · 8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type. |/ *2; Imploturbocompressor; Imploducted, One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Imploducted Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature. http://stateoftheartnovelinflowtech.blogspot.mx/
edthelegendary wrote 09/22/2019 at 05:09 point
It will surely be better than the Instructables app. Lol. (No sarcasm intended. The Instructables app is terrible.)
davedarko wrote 09/19/2019 at 10:08 point
It only pulls projects from 2014 till 2017 for me :D the last one is the 433MHz MQTT thing, I presume it's capped somehow?
And after creating and posting a new log, the app crashed. Also the fire emoji was converted to a question mark.
Rocking a Samsung S6 edge, Android 7.0 - cool stuff though!
davedarko wrote 11/17/2019 at 22:47 point
man this place got spammed o.O this is still a current problem for me
Michael Cullen wrote 09/15/2019 at 16:44 point
nice idea! It would be nice to be able to add logs without pictures though
Brian Gilbert wrote 11/19/2019 at 02:28 point
Same here. I would also like to be able to start a log with text, and then take a picture after I've started.
Miroslav Zuzelka wrote 09/09/2019 at 17:46 point
@Grant Giesbrecht + 1
+ I would love in this version to be able also create project and start to insert photos in it
kwapiszon wrote 09/09/2019 at 12:55 point
I would like have a account on mastodon on hackaday, cell phone ap? no not for me
omarmung wrote 08/21/2019 at 22:21 point
Nope, not yet.
Suren wrote 07/08/2019 at 19:55 point
..hi.... have anyone tried programming a single board esp32 lyra T for a webradio yet ?
Philip Ashmore wrote 07/04/2019 at 13:17 point
Is there a git repository for this? I'd really like to know the secret sauce to integrate photo capture to my Android app!
Richard Hogben wrote 08/21/2019 at 22:40 point
Whats your Android app?
Philip Ashmore wrote 08/22/2019 at 06:14 point
A solder oven controller, written in Qt so I can debug it on my laptop over serial.
On the phone it uses bluetooth.
It helps to see a picture of the oven on the background so you're using the correct PID settings.
Since it's a phone it would make sense to just snap a picture of a new oven in the app before calibration.
Grant Giesbrecht wrote 07/04/2019 at 03:15 point
Nice! I've always wanted a Hackaday app and I'm glad to see movement in that direction. I'd love to see a full-fledged app which lets you view and search projects, post comments, edit projects, etc.
Richard Hogben wrote 08/21/2019 at 22:41 point
Thanks! The current version is purposefully simple to gauge interest and further development.
