The main impediment to my progress has been how to automate the feeding of carbon rods into the gas generator, so here the idea sits...
Ok, so if you arc weld underwater, the gas produced is a hydrocarbon that could be used to store the energy produced from wind/solar.
I know I am 9 years late, but Seeing that your problem is the replacement of the carbon rods, why not instead using tungsten rods and a carbon enriched water (as sewage) to create the gas? Tungsten erodes much slower.
