The Deep Indie Go Go Campaign: D.C's Dancing Jellyfish Chariot
07/11/2016 at 19:26 • 0 commentsWith less than 54 days until the Man Burns, our team is hot on track to get the version 2.0 version of the Deep completed.
Now that the Deep 2.0 Indie GoGo Campaign is up, come out and help contribute to us finishing up the 2nd version of the artcar and getting it out to the Burn!
https://www.indiegogo.com/projects/the-deep-2016-dc-s-dancing-jellyfish-art-car--2#/
Customized Deep Logo Tin Cup for Your Donation
06/19/2016 at 17:45 • 0 commentsSo, I'm right now working on the Deep version 2.0 with my team, and we're facing what every Burning Man Art project faces as their primary foe. Lack of funding. We're right now coming up with a reward product for our next indie gogo campaign, and I want to put some feelers out there to the hackaday folks about what y'all feel.
For the Deep 2.0, this is what we're working on accomplishing before the burn:
1.) Building the electronics for the simulation of the Comb jellyfish lights, which are synchronized to music and respond to movement, like a real jellyfish. Because we've all seen musically reactive jellyfish...
2.) New decorations that are durable, non-MOOPY, day ready, cleanable, on the Deep Art Car, to make it more seaworthy in the middle of a desert, the woods, or a sandy beach.3.) New Spare Battery, so we don't have to abandon art car in the middle of the desert
4.) Transport costs, so we can get the Deep out to the Desert
5.) Spare parts for repairs in the desert
6.) Soft robotic tentacles to hug people.
These are the questions I'd like to ask y'all who are following the Deep.1.) Would you donate to the Deep Art Car? The plus is you already know that we've built the Deep 1.0. We've got the pictures and videos to prove it. So you know we're not a fly by night operation.
2.) Would you consider donating $50 for a customized tin cup with the Deep Logo on it. It looks like this, thanks to the mad machinations of Marina.This is what the metal cup would look like:
Feel free to comment below.
Jellyfish Bell v2.0 Electronics
06/17/2016 at 21:30 • 0 commentsThis is the initial circuit diagram for one of the sensor nodes. It's going to get expanded into a sort of hybrid digital/neural circuit emulator design, using a synapse discharge as the main model. The entire Jellyfish will have about 11 microcontrollers, right now, they're independent of each other. In the future, or near future provided we have time, they'll be networked with each other in a mix of analog circuitry that simulates a neural synapse, using the high output of a digital circuit as a discharge signal, and that interfaces with digital circuitry. I call it the "Wannabe Jellyfish Cyborg."
This is just the first sensor node which controls the RGB LED strips.
This is the overall diagram of the concept.
Obviously, because the signalling is going to be digital, there aren't going to be any weights. The only thing that can be weighted is from the sound sensors, and that we're not going to use for the time being. I know, some of you are probably asking, "then what's the point?" There is no point other than to create a signal that fires off in analog at various points around the bell creating... ART!
And, here's the basic code.
The Deep Combjelly Simulation Code -
Making the new Jellyfish Bell
06/17/2016 at 18:10 • 0 commentsLast year, we were scrambling to get the Jellyfish art car ready for the burn, which meant taking the path of least resistance. The result was our jellyfish bell looked like a mushroom with tentacles. This year, with more time we've started building the second jellyfish bell frame.
Me and Marina with the new frame inside the old envelope.
We made the frame from a 6 junction pvc construction piece - you have to special order it online - and some pvc pipe from home depot. We used a heat gun to soften and form the pvc pipe into the shape you see above. I first got that idea years ago when I made my own PVC bows and arrows from this guy out in Hawaii.
And I just repurposed the technique to make the Jellyfish ribs. Next up, electronics!
Sea Shells Made out of Paper Mache and Mortar
06/13/2016 at 17:02 • 0 commentsCarrie and Marina are hard at work lending their incredible design and creative talents to creating the next version of the Deep Art Car's ocean themed mutations. Using an interesting mix of paper, and mortar - this $#!T is fireproof - they've crafted some beautiful creations of the oceans. Check out their simulacra...
Marina and her sea conch.
There's more to come! We're hard at work getting ready for Burning Man 2016, Transformus 2016, and Playa Del Fuego Fall 2016!!
The Deep v2.0 reactive LED/eye system
06/13/2016 at 16:34 • 0 commentsOne of the characteristics we wanted to do with the Deep that we didn't have enough time last year to do was to make the jellyfish reactive, you know, like a real jellyfish. So, for this year, among many many other improvements, I've been working on a circuit that has more biological behaviour.
The BOM is an arduino compatible boarduino, from adafruit, https://www.adafruit.com/products/72, a neopixel RGB strip that uses the neopixel LED strip, https://www.adafruit.com/products/2832, and a cheap ass pir sensor from ebay. Note to anyone who's attempting this, the RGB strip draws a lot more power out of the boarduino, whether from the USB (which you shouldn't be using), or an independent power supply! Because of that, the pir sensor wasn't picking up and the digital port it was attached to kept flashing high, triggering the program code. To fix this, I attached a 3V source to the pir sensor, using this information: http://techgurka.blogspot.com/2013/05.... Now the circuit works perfectly. Also, instead of arduino, which I used to rapid prototype, I'm moving to the msp430g2553 instead for its low power characteristics.
You can see LED color pattern is similar to a comb jellyfish, like this
Using the pir sensor, we can start approximating some of the jellyfish's reactive characteristics, in this case to movement/light. Circuit design and code to be put up shortly.
The Deep @ Love Burn
04/21/2016 at 16:08 • 0 comments -
The Deep 2.0, 2016 Edition
04/19/2016 at 03:33 • 0 commentsThe Deep successfully debuted at Burning Man 2015, Love Burn 2015. Next up is the Freeform Arts and Transformation Burn and what many on the East Coast consider the best Burn around - there are people who sell their Burning Man tickets just to go to this Burn - Transformus. For that one, we're getting into the Deep 2.0, Soft Robotics edition! Here are the design concepts going into this year's iteration.
As for Burns, being a burner doesn't mean Burning Man itself. It means embracing the 10 principles, which is why so many Burners I know don't go to Burning Man. A lot of them go to regional Burns. Burning Man just happens to be a very very large Burn regional to Nevada. But the future of that movement, IMO is in the regionals.
Lights and the Deep's Maiden Voyage
04/19/2016 at 02:48 • 0 commentsThe active lighting system, which consisted of RGB light strips, was programmed on a Teensy LC. For the next version of the bell, I'm programming it to be responsive to sound and to randomize and re-order the light patterns depending on the kind of musical input it gets. Like a proper reacting neural network would.
And this is the Deep's very first test drive out of the workshop!
Video of the Deep's First Full Assembly
04/19/2016 at 02:23 • 0 comments
