Introduction
Everything was going nice with my custom Arduboy, after painting the PCB with a sharpie marker, I just need to reattach the LCD and paint the buttons with a shiny gold color.
All the other Arduboys are looking how the gold paint gets dry. But the paint never got dry:
Now I have no buttons. The paint melted a layer of the coating and I had to discard them.
Design
A and B buttons
These are quite simple. Copying the dimensions from the original ones I get a simple profile:
Then you have to revolve the profile around the right side vertical axis and you get a nice button:
Directional buttons
These are more complex because the shape is not a primitive. My first design is composed by two simple shapes and several fillets:
Using freeforms, I can replace the top part with a more organic shape:
Done. The directional button is ready.
Problems
So, it seems like my printer saved the Arduboy. Now I can assemble the console and play... right?
After few seconds I notice that the buttons are crap. You have to press them extremely hard to get a key-press registered. Something is wrong. The only difference with the original ones is a protrusion in the bottom. Of course, I cannot make that protrusion because FDM 3D printing limitations.
I printed so many versions trying to achieve that protrusion... nothing worked.
Sometimes you need to think out of the box, what if I did not print that protrusion but used filament for creating what I needed:
A piece of filament goes sideways (to use the constant diameter of the filament to my advantage) in a hole, below each button.
Conclusions
After playing for several days with them, I can say that the new buttons are perfect. And since you cannot buy button replacements, there is no really another way to fix your Arduboy.
I cannot perceive any difference between the printed buttons and the original ones just by touching them. But I am printing them at 0.05 layer so the finishing surface is really smooth on the fingertips, so maybe that is the reason.
eried
Conclusions
Maave
Christopher
rkrishnasanka
This gives me confidence that I'd be able to print some buttons for my EXPLOG project. Your prints look great.
