Custom PCB Finalized
A project log for Gas Sensor For Emergency Workers
Gas sensor "grenade" that may save lives instead of taking them. The sensor can be thrown into dangerous areas to remotely report levels
eric-wiiliamEric Wiiliam 07/28/2015 at 05:336 Comments
Finally got around to designing a custom PCB for the gas sensor. I am entirely new to using Fritzing so I decided to simply use the Arduino Nano as it was without breaking out the chip, supply etc. This isn't the best use of space but should make this super easy for anyone to replicate.
The PCB design went really quickly and I was able to export the design files in an hour or so:
Off I went to the OSH Park website to use the credit I received from an early bird prize in the Hackaday 2015 contest. The PCB's were really cheap and I ordered- but 5 minutes later I found a serious error in the design- so I re-ordered again :)
Version 2.0 looks promising and once I have verified it works I will post all the design files so everyone can create their own version. Super happy with this project and loving that it has been well received with the open source and electronics community.
Cheers
Eric
Rich text editor
David Watts wrote 07/29/2015 at 20:18 point
Nice, I hope you connected both of those ground planes :-) Really looking forward to seeing the OSH Park board once it arrives.
davedarko wrote 07/29/2015 at 22:00 point
they should be connected through the through-hole pins on the arduino, or not?
David Watts wrote 07/29/2015 at 22:21 point
Ha ha, they will be. It was in reference to a conversation we had about the first board I ever made that was milled and not printed at OSH Park.
davedarko wrote 07/29/2015 at 22:49 point
well thanks to this comment I've noticed that project, so thanks guys :)
Eric Wiiliam wrote 07/30/2015 at 01:04 point
:) Dave
:)  Damn I feel your pain now- I just about pulled my hair out on the Garden PCB.  Then I messed this one up so it's on rev 2.0 already.  Hope it works!
