Hackaday.io Hackaday.io
Sign up Log in
Bluetooth LE Pager
Motorola Bravo pager fitted with BLE guts.
dhgoldbergdhgoldberg
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.4k views
4 comments
3.7k followers
  • Description
  • Details
  • Files 0
  • Components 8
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
4.4k
4
3.7k
12
Team (1)
  • dhgoldbergdhgoldberg
Join this project's team
hardware
completed project
arduino bluetooth
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 03/15/2015 and last updated 2 years ago.
Description
In this project I take an old Motorola Bravo pager and replace its insides with my own PCB that fuses an ATmega328 (with Arduino bootloader), Bluetooth Low Energy, a vibe motor, a piezo buzzer, and some ws2812b leds. The original form is maintained, including AA battery power and two external buttons.
In it's current state, the pager beeps, blinks, and buzzes whenever I get a text message. It's a bit silly, sure, but a fun exercise in reverse engineering and design.
This is primarily a hardware project, so minimal effort was put into the Android and Arduino coding.
Details
Components
  • 1 × ATmega328P Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × Adafruit Bluefruit LE
  • 1 × Pololu 5V Step-Up Voltage Regulator (U1V11F5)
  • 1 × Sanyo Vibe Motor NRS2572
  • 1 × Piezo Buzzer
View all 8 components
Log In/Sign up to comment
Sign up with Github
OR
dhgoldberg wrote 02/14/2017 at 22:15 • point
@josephchrzempiec I wrote my own android application to interface with the bluetooth module.  It was very ugly.  I'd check out one of Adafruit's examples.  This might get you started: https://github.com/adafruit/Bluefruit_LE_Connect_Android
For the arduino sketch, Adafruit has a nice tutorial here: https://learn.adafruit.com/getting-started-with-the-nrf8001-bluefruit-le-bre
josephchrzempiec wrote 02/14/2017 at 23:19 • point
Hello  i looked all around and i couldn't find anything to help me out the adafruit one didn't really help me because the lack of skills i need for the arduino app. I need someone help to help me make one. As far as the sketch goes the one from adafruit someone pointed me in the right direction but really didn't help me much.
josephchrzempiec wrote 02/11/2017 at 04:23 • point
Hello i been trying to get a hold of you to ask which application did you use to interface the bluetooth module with the android phone and sketch can you please help me?
josephchrzempiec wrote 02/06/2017 at 19:55 • point
Hello i have a question i have the same bluetooth module and i was wondering where can i find the sketch to make this work? And what do i need to make it work with my phone.
Budget Electric go kart build that focuses on functionality and design
Project Owner Contributor
E-Kart: The electric Go Kart
adrian-georgescuAdrian Georgescu
Tiny DIY programmable IR remote that's based off the arduino uno (backwards compatible with my orginal Remoteduino project)!
Remoteduino Nano
sjm4306sjm4306
About This Project This is an automatic Transistor Tester, to identify pinout and characteristics of various discrete semiconductors
Transistor Tester
romeo-hacksterRomeo hackster
The 2015 Hackaday Prize
The remote will only have a few buttons, each can be programmed by pointing the original remote to this self-learning remote.
Self-learning TV Remote for the elderly
hari-wigunaHari Wiguna
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Bluetooth LE Pager", please tell us the reason.
Send message
Remove Member
