Download the testing image.
07/28/2015 at 09:09 • 0 commentsIf you are interested to help with the testing and then I highly recommend downloading the testing image here
Recently I made a blog post about the project, you can read it on my blog. http://playingwithsid.blogspot.com/2015/07/mozilla-webmaker-tools-on-raspberry-pi.html
Alpha Release: Testing only!
05/07/2015 at 12:05 • 0 commentsReleasing a alpha testing version of the image. Please download and write a 8GB/16GB card.
https://dl.dropboxusercontent.com/u/50372706/Raspbian-webmaker-alpha.img.tar.gz
Tracking changes upstream
05/07/2015 at 02:13 • 0 commentsThere has been some changes to Thimble design upstream. Perhaps I have to incorporate those changes in the distro.
Upstream discussion here:
Nginix + Supervisord + NodeJS
04/15/2015 at 11:03 • 0 commentsWhen you call 'webmaker.local' the Thimble project loads. \o/
https://github.com/arky/Rasbian-Webmaker/commit/0831cd538dacf8fcbd5a7e584b2fcd5959d07722
Old Notes
03/20/2015 at 13:41 • 0 comments
Resized root partition to > 4GB- Packages Installed: ntpd, nodejs, wicd-curses, hostapd, udhcpd
Change default locale to en_US.UTF8- Change default keyboard to en_US
- Hostname changed to WebMaker
- mDNS configuration exposes 'webmaker.local'
- Aditional Wifi configuration Wicd curses tools installed
- Install Node.js Version Manager (NVM)
- Log to to tty8
- Node-Service and Node-Init scripts https://github.com/nicokaiser/node-init
Wifi Captive Portal
03/20/2015 at 13:35 • 0 commentsSetup hostapd and dhcp. However the ip address are not assigned to clients.
https://learn.adafruit.com/setting-up-a-raspberry-pi-as-a-wifi-access-point/install-software
