SMD 0201 Challenge
Are you proud of your surface mount soldering skills? Here is a CR2032 cell battery powered badge to challenge you.
It is not difficult to hand solder the SMD of size 0805. How about size 0603, 0402 or 0201? This badge gives you all of them. This badge is a binary counter. It has a 555 timer and a CD4020. Here is the tindie link, https://www.tindie.com/products/nwmaker/smd-0201-soldering-challenge/
[deleted]
nwmaker wrote 08/18/2018 at 21:08 • point
Just send some tips to you via Tindie. If you still need any clarification, I'd love to help you out.
zakqwy wrote 02/12/2018 at 16:32 • point
love the trace design! did you use PCBmodE?
nwmaker wrote 02/12/2018 at 18:58 • point
yes.
