Raspberry Pi : Python Flask web server
This is about writing a website and exposing REST JSON APIs on Raspberry Pi. For this I used Python Flask.
I am working on an a Raspberry Pi based, internet connected indoor air quality monitor called LiV Pi. LiV is an open source hardware and software project. LiV measures temperature, humidity, air pressure and CO2 levels. I connected LiV to my home network. I wanted to be able to have a Intranet website on LiV where I can to see real time measurements and graphs. I used Python Flask to do that. I also exposed REST JSON APIs in Flask. The APIs can be used by developers who would like to integrate LiV data with their applications.
Detailed info on LiV Pi here:
https://www.tindie.com/stores/AlfredC/
http://www.livpi.com/
  • 1
    Step 1
    You need to have Python configured on your RPi.
    - Install the following libraries: flask, python-matplotlib (if you want to have data visualization)
    - download the LiV APIs Python code from the gitHub repository listed before
    - modify the code to suit your needs
    Send me a message if you need any help or if you spot anything that I should improve in the code.
View all instructions
Luke Beno wrote 08/22/2015 at 20:15 • point
Cool project!  Would you at all be interested in connecting your sensor to my project?  https://hackaday.io/project/4648-analogio
AlfredC wrote 08/25/2015 at 02:21 • point
Hi Luke. Please send me an email at: support aT firstcypress Dot com to talk about this.
