I hope i make it to the next round
08/18/2015 at 00:17 • 0 commentsHi, i uploaded the video today, tomorrow i´ll be posting some photos.
I had to wait to the last minute because i wanted the system to be operational for the video, but i'm having some troubles with shaky servos and not much sensing sensors. It worked fine in the simulated version that I designed on 123d circuits, but real life is hard...
Hopefully, i´ll soon make a new video when the system is fully working and also i´ll upload the arduino code.
getting there
08/11/2015 at 02:58 • 0 commentsalmost finished
08/07/2015 at 00:29 • 0 commentsThe code worked very well, so i decided to make it more complicated. I added a reserve tank to save more shower water if the toilet tank is full with an overfill-avoid-pipe. The new code works well also.
There's a new drawing to show the modifications. I am keeping the previous ones as references.
The scale model is halfway done, probably i'll finish it this weekend.
Schematic
07/30/2015 at 19:59 • 0 commentsSorry for the autorouting (i made while working), i'll post a proper schematic later
Code is done
07/30/2015 at 18:52 • 0 commentsThe code is done and working. It wasn't as hard as i expected.
The servos and LED´s are working fine.
Now i can start building the scale model y test it.
Soon i'll post pictures of the build in progress and next.. "The video"
Coding
07/28/2015 at 02:44 • 0 commentsDealing with the code for the ATMega328 to drive this project...
I am learning as i go, I hope that it's finished on time.
Update
07/25/2015 at 01:15 • 0 commentsI have changed the concept design a little bit (i left the previous one for reference)
I've started playing with the servos, soon i´ll be posting pictures of the making of the scale model.
update
07/01/2015 at 01:08 • 0 commentsI'm thinking about adding a Rainwater tank as backup/expansion.
Soon i´ll start making the scale model
updated components list
06/10/2015 at 22:39 • 0 commentsI updated the list of components, still a few missing
Shower water repurposer
05/21/2015 at 13:12 • 0 commentsAdded concept drawing
Next will be adding system details
Later build a working scale model
leandro
