Hackaday.io Hackaday.io
Sign up Log in
energy wristband
helping children to learn about electrical energy in the home
matt-vennmatt venn
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.4k views
3 comments
39 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 3
  • The 2015 Hackaday Prize
View Gallery
2.4k
3
39
13
Team (1)
  • matt-vennmatt venn
Join this project's team
  • design files and log
hardware
ongoing project
energy monitoring 2015HackadayPrize BestProduct
Related lists
2015 Hackaday Prize: Quarterfinalists
Projects that were officially submitted to the 2015 Hackaday Prize
Microchip Parts
Projects using Microchip hardware
2015 THP: Microchip Parts
Hackaday Prize Entries using Microchip parts
This project is submitted for
This project was created on 03/27/2015 and last updated 5 years ago.
Description
A wristband that tells you energy changes in your home. It connects via a Raspberry Pi computer to a base station like a 'current cost' or similar. When a change in energy usage occurs, the wristband vibrates and a small LED bargraph shows your current usage from 1 to 4.
Realtime energy use can be queried by pressing the button.
Project Logs
Collapse
  • UK Maker Faire 2015
    matt venn • 04/30/2015 at 09:05 • 0 comments
    Ross gave me back the wristband after a few months of testing. They'd made a nice case at DoES Liverpool (https://twitter.com/cheapjack/status/591216586276605952) that was based on some real energy data!
    I made a little test house so people could try turning on and off various appliances and feel the wristband in action.
    One of the problems I had at the start was very unreliable bluetooth communications. When I ran `hcitool lescan` I found hundreds of devices due to all the mobile phones nearby! Increasing the timeout used by `gattool` to 20 seconds improved reliability a lot.
    Some photos of the wristband project at the UK Maker Faire 2015 (https://plus.google.com/u/0/photos/109869064118515349190/albums/6142516349786315393)
    And I've updated the beta tester instructions with a nice picture of all the parts (https://github.com/mattvenn/energy-wristband/blob/master/docs/closed-beta.md)
  • UDP repeater - or increasing range
    matt venn • 03/27/2015 at 16:33 • 0 comments
    The main issue with the system is that bluetooth low energy just doesn't seem to have the range. I've tried extending range by hacking the aerial, but it doesn't make much difference.
    After putting the dongle on a usb extension cable at my parents the range got a lot better. I'm assuming that getting it further away from the wifi dongle (both at 2.4GHz) reduced interference and improved range.
    Strangely, doing the same thing in my (much smaller) flat - it didn't make much difference.
    So how to increase range. Well my laptop is on a fair amount, so while it's on why not use its bluetooth to pass the message on if the wristband is out of range from the pi?
    If the daemon is started with --udp_repeat then it will broadcast any wristband messages (default 192.168.0.255).
    The udp repeater program can be started at boot, and will pass on messages received over UDP to the wristband if it's in range.
  • old logs
    matt venn • 03/27/2015 at 16:32 • 0 comments
    Older log posts are here https://github.com/mattvenn/energy-wristband/blob/master/docs/project_log.md
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
peter jansen wrote 03/28/2015 at 01:48 • point
neat idea!
matt venn wrote 03/27/2015 at 20:33 • point
thanks!
zakqwy wrote 03/27/2015 at 17:18 • point
I love this--helping kids understand energy consumption at a young age is a great idea.
As a part of my work/private investigation regarding sensor networks and Internet of things, I am discovering the works using a toy project.
Project Owner Contributor
Smart Greenhouse using a Raspberry Pi & Launchpad
eelcorouweelco.rouw
A portable studio based on the Raspberry Pi
Raspberry Pi PortaStudio
austin-martinAustin Martin
The 2016 Hackaday Prize
Decentralized Autonomous Interconnected Systems for Energy Efficiency - A blockchain based energy DAO
[2016] InternetS of Energy - Call me DAISEE
rieul-techerRieul Techer
Digital, portable, open source, and simple checklist for every day carry. Replace apps and paper for good.
Open Digital Checklist
dustinDustin
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "energy wristband", please tell us the reason.
Send message
Remove Member
