« Back to project details
Assemblying the components to form the printer
02/13/2018 at 12:32 • 0 comments -
Filing of the 3D components
02/13/2018 at 12:24 • 0 commentsSince the 3D printed components were not precise and their supports were protruding out, we had to file them the extra part to make them precise.
Modifications made in the wheel attached to the pin head
02/13/2018 at 12:20 • 0 commentsWe made modifications in the wheel that is attached to the pin head encoder. The 3d printed wheel had some gap between them due to which there were levelling issues. Due to this problem the wheel had stability issues and was toppling.
We attached some padding (Double Sided Tape)
on both the surfaces of the wheel in order to give it some stability.
Fabricating Pin head encoder
02/12/2018 at 13:53 • 0 comments -
Laser printing the body of the project
02/12/2018 at 13:41 • 0 comments
