DAY 2 - FABRICATION AND SIMULATION
02/13/2018 at 14:21 • 0 commentsDAY 2: Completed sourcing of the materials for making the chassis based on the 3D modelling. Fabrication of the chassis was completed with bending, welding, and so on. And setup a simulator to test the load distribution of the chassis and harness. Based on our simulator testing, the harness of the parachute was attached to the chassis.
DAY 1 - PROTOTYPING AND 3D MODELLING
02/12/2018 at 14:03 • 0 commentsDAY 1 - We took measurements for several different demographics which included the Indians and the french to get general measurements that we could use to build the chassis. Further, we designed the 3D model on fusion 360. Finally, we built a scaled prototype.
