An Adequate receiver coil is needed for this mod, go for the slimmest you can find, 2 pin and don't go super-cheap. need around 800ma (rated).
It's good to test the coil first with a multimeter if you have one, mine was 4.92V(good) I removed the outside foil from the receiver and noticed the coil worked on its own but when the Phone was on top of the Coil, it did not charge. Placeing the NFC sticker behind the coil shielded the coil and fixed the problem, the nfc coil has to be behind the qi coil anyway i also connected a micro usb cable to it to see if it would actually charge the phone. i recommend this the wire you use needs to be capable of carrying 1a and be small enough to fit. if it dont fit then you may have to start cutting plastic. the receiver i used a nice length of wire anyway
Ollie Smith
RoGeorge
Gertlex
