I'm thinking about this project more than year. Now it´s time to make it real! Almost all parts are already sourced, so let's build it!
Making an electron gun is a first stage of my future plans - to make DIY electron microscope/EBM metal 3D printer.
100 kg of iron. It require few modifications, but with this chamber it will be possible to increase acceleration voltage and stay safe from x-ray.
Chamber was donated from ThermoFisher Scientific, thank you :)
Just quick vide for small grant application. More detailed video in english will follow.
Melted solder on anode. About 200W by an accident.
As a next step, i need to redesign HV feedthrough. I used to use spark plugs, but for filament @2Amps, the spark plug resistance increased slowly from 5R to ~15 Ohm each. That is an issue, since the filament has 1 Ohm and Im using 6s RC battery with stepdown. So there is no headroom for proper regulation.
I'm wondew what is inside of the spark plugs, or why the resistance increased.
Im facing hard decision to discard whole setup and start again. I want to increase accelerating voltage to 30kV. But with current setup with glass jar, it is big no no due to x-ray.
Also the electron gun deserves proper calculations/simulations.
Last thing is that e-gun is classified in my country as "small" sources of ionizing radiation and undergo regulations. The State Office for Nuclear Safety has trainings for radiation safety, which is not that expensive. Maybe it is time to refresh some knowledge.
It will require some fundings to move to the next stage...
Boys from our hackerspace are afraid of glass jar implosion :) This is the metal frame which will be covered by fine metal fabric.
New silicone gasket for better vacuum.
@MakerFaire
A lot of progress in these days.
Three days left to Maker Faire Prague ...
Done with vacuum controller, time to make some HV :D
STM32->gate drivers->full-bridge at 50kHz->transformer>500W dummy load.
SMPS_1: Isolation transformer
SMPS_2: classic buck converter
SMPS_3: step up
SMPS_4: current or voltage fed voltage converter - depends on power (e-beam weldes vs SEM)
Hi, it's been a while since the last update. How is your project going ?
Hi, sadly no progress at all during last year. But expect an update about hvpower supply within month or two.
Hello! Really great project, was wondering if it is still being worked on?
I'm no expert but I Believe the idea is to bind some metal powder with an electron beam. then add another layer of metal powder and bind it. etc etc until you have a finnish part
My friends and I would very much like to help you complete this project.
