Hackaday.io Hackaday.io
Sign up Log in
A basic IoT device
A basic small-as-possible IoT device, watching the house.
kjohKJoh
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
1.2k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
494
2
1.2k
2
Team (1)
  • kjohKJoh
Join this project's team
ongoing project
This project was created on 04/26/2015 and last updated 6 years ago.
Description
In addition to my interest in autonomous systems, I'm totally into seeing data about the world around me. I had some initial forays into IoT with Thingspeak, and wanted to continue that.
E.g. What's going on with the temp and relative humidity in the house. How often / how ling does the furnace / AC run?
I started with a basic AM 2302 humidity sensor, first plugged into an arduino, then a atmel 168p. I want this to be as bare bones as possible. Connectivity will be via ESP8266 whenever they arrive in the mail.
Project Logs
Collapse
  • Clean up, and on to part 2
    KJoh • 05/09/2015 at 11:57 • 0 comments
    cleaned up the board, still talking to it with the arduino.
    If anyone wants to check it out, go to
    https://thingspeak.com/channels/37003
    Pretty standard stuff, probably been done a million times, but, still.....yay?
  • A start
    KJoh • 05/07/2015 at 19:46 • 0 comments
    always good to start with a simple arduino sketch, though I intend to program this as a standalone avr based device.
    Thanks to
    https://github.com/hwiguna/g33k/blob/master/ArduinoProjects/RF/ESP8266/esp8266_ThingSpeak/esp8266_ThingSpeak.ino
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
KJoh wrote 05/03/2015 at 12:27 • point
Just because.  First off, I wanted to try to integrate the esp8266 with the avr as an exercise, but also want to do more than just temp and humidity.  Plus, I don't have one yet ... Still waiting for my 8266s to arrive.  Thanks for looking
vlatkokaplan wrote 05/03/2015 at 12:21 • point
Why are you going to use atmel168p? I have mine DHT22 connected to esp8266.
Official Hackaday Prize Entry
Integration of cheap wireless Arduino sensor nodes with an awesome home automation platform called OpenHAB. Explore interface options.
Project Owner Contributor
$20 Wireless Arduino Home Automation w/ OpenHAB
eric-tsaiEric Tsai
A simple DIY Arduino-based device to measure the input-to-action latency in 3D games.
Arduino Latency Meter
eugene-fainstainEugene Fainstain
Two simple local projects to introduce you to the basic finctions, and some of the possibilities of this Arduino Kit.
Arduino OPLA IoT Kit Blink Example and Symon Says
mircemkmircemk
An Arduino-based device connected to the interwebs by GPRS to monitor and log events online using Carriots and Google Sheets
Internet-connected monitoring with Arduino & GPRS
adriajunyent-ferreadria.junyent-ferre
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "A basic IoT device", please tell us the reason.
Send message
Remove Member
