1Step 1
You'll need a transformer and a suitable box / enclosure. Find these first.
2Step 2
Find a heatsink for the transistors. Mount them there, including the emitter current equalising resistors. Mount the entire assembly on your project's enclosure
3Step 3
Build the PCB using your preferred method. I designed this with through hole components, so anyone can solder this circuit. Complete your board, connect it to the transformer, LCD, and buttons.
4Step 4
Download the code to the Atmega8, you can use the prog.sh script that I've provided. Don't forget to write the fuses, we're using 16MHz crystal here.
5Step 5
You're good to go. Enjoy your new work bench power supply!
