This project deals with the problem of air pollution in large populated countries. I come from a country where most people use motorbikes/scooters as their daily commute. Hence the helmets. Most of them don't even have a air filter. Even if there are some conventional air filters helmets they just are not up to the mark. My project is an effort to make the process of air filtering efficient and easy, and also commercially viable. Also it helps to trap harmful gases, hence when these kind of helmets are used in large quantity by the people, it might solve a little part of the ongoing crisis against air pollution.
Components
1×
Helmet
Any Bike helmet which fully covers the Head
1×
Small DC Motor and Fan
Low voltage rated motor suits best for this scenario
1×
Air Filters
(Activated Charcoal, HEPA) to name a few
For the filtration a dense activated carbon filter + hepa with assisted ventilation would be ideal. I'd happily pay serious money for the helmet and filter replacements if something like that existed.
not an easy one to solve. How are you planning on filtering the air ? do you wanna use something passive like a few layers of different materials, or are you planning to pursue a more active method ? something that would require decomposing the chemical structure of the intake.
