1Step 1
Download the scad file from files section and generate the 3d model in openscad, or skip this step and print from the attached .stl file.
OD = 31.9; //outer width OH = 15; // height of main cylinder ID = 5; //inside diameter for mounting hole KD = OD+10; //outer diameter for knob KH = 10; //height of knob SD = 6; //shaft diameter SH = 10; //shaft height module knobMain (){ cylinder(OH,d=OD); //main cylinder //grip cylinder with grip on outside translate([0,0,OH+KH/2]) cylinder(KH,d=KD,center=true); } module knobCutout (){ difference(){ //cylinder to remove center hole translate([0,0,-0.1]) cylinder(h=SH,d=SD); //keep the tab on the switch #translate([SD/1.5,0,(SH/2)-0.1]) cube([SD,SD,SH], center=true); } } module buildMain (){ difference(){ knobMain(); knobCutout(); // this cuts out the small indents around the outer edge for (i = [0:360/7:360]) { rotate([0,0,i]) translate([KD/2,0,OH+KH/2]) cylinder(KH+0.1,d=KD-OD-2,center=true); } } } buildMain();
2Step 2
You may need to enlarge the inner hole to suit your printer and rotary switch. generate the .stl or use downloaded file. Print 3d part.
3Step 3
Use sand paper to smooth the corners and printing artifacts if necessary. I use a kitchen stove gas flame to smooth the plastic scuffs after sanding.
4Step 4
Use a black marker pen and draw a triangle to indicate the switch position if you like. See if you can do a better job with the pen than me.
