1Step 1
Kernel Module.
- Install the correct kernel headers
sudo apt-get install linux-headers-uname -r- Make backup of existing pruss_remoteproc driver (if any)
sudo cp /lib/modules/$(uname -r)/kernel/drivers/remoteproc/pruss_remoteproc.ko /lib/modules/$(uname -r)/kernel/drivers/remoteproc/pruss_remoteproc.ko.back- cd to /drivers/remoteproc in cloned repo and run 'make' command
make- Install the compiled module
PRU firmwaremake install- Install TI-PRU Code generation tool from this link
- Clone TI's PRU software package library from this link to any suitable directory.
Example
cd /usr/sharegit clone git://git.ti.com/pru-software-support-package/pru-software-support-package.git- Edit /firmware/Makefile variable SWDIR to the directory in which you cloned repo in Step 2 (skip this step if you cloned in /usr/share)
- cd to /firmware
make- Install firmware
if above steps are performed on host PC
make install-tobbif above steps are perfomed on BBBmake install-frombb
- cd to /userspace and run 'make' command. This will compile the library and examples
make
Shubhangi Gupta
