Week 11 Progress
08/19/2015 at 05:38 • 0 commentsDevelopments:
1. Exposed vring to userspace using misc device which provides streaming data from pru to arm.
2. Proper code alignment and commenting. Not completed yet.
Issue:
Blocking read on misc device still facing synchronization issues. This involves correcting flow of pending buffer interrupts sent by PRU->ARM and their subsequent transfer to userspace by copy_to_user.
Next Week:
Wrapping things up, example code and documentation -
Week 10 Progress
08/19/2015 at 05:37 • 0 commentsDevelopments:Earlier I was able to write to all 512 (or less buffers) from PRU but they were not being added back to the vring (as free buffers) after the data was consumed by host processor. This last roadblock (hopefully) has been solved hence resulting in successful transfers from PRU to ARM, even continuous streaming data using the vring :D
Issues:
One major optimization remains i.e I am able to get different transfer rates depending on what frequency one kicks (ie interrupts) the ARM. Kicking the ARM after writing to each 512byte buffer followed by a kick results in stalling the ARM because of too many interrupts within too short a time. Kicking after filling all 512 buffers have been filled in bu the PRU leads it to wait for ARM to consume
buffers first before PRU can start using them again. So, in order to attain maximum throughput, an optimum value needs to be found out after which the ARM is kicked. The user also has freedom to decide this value on his own (in the pru firmware) depending upon his requirements.
Next Week:
Patches for 4.1 expose misc char device to stream data to user. -
Week 9 Progress
08/19/2015 at 05:36 • 0 commentsDevelopments:
I am running a slightly behind schedule. Instead of exposing vrings to userspace I worked on allowing custom callbacks for virtqueues which are executed after the kick. These callbacks are necessary consume pending messages. Pushed code to gh.
Issues:
Lately I have been able to spend a little less time than I should have. Need to cover up.
Next Week:
Finish previous weeks objectives as fast as possible and get back to working on 4.1 patches. -
Week 8 Progress
1. Virtio based vring communication now works for PRU. However things are still within the kernel.
2. Test firmware for pru cores which provide vdev info to rproc driver through resource table.Communicate data using buffers (vrings) and inform other processor of pending data using 'kicks' which are actually sysevents.
Issues:
Single biggest issue which was most troubling was to find location of resource table within PRU DRAM.
Solution : the .resource_table SECTION specified in link (am33xx.cmd) file is written to a fixed address.
Next Week:
Expose vring to userland as char device and test performance. -
Week 7 Progress
08/19/2015 at 05:35 • 0 commentsDevelopments:
1. vrings are allocated automatically from remoteproc driver if they are present in firmware resource table. Currently 2 vrings are permitted ( RX and TX ) each with 512 bytes sized buffers. Number of buffers in each ring can be maximum 512
Issues:
1. Patches for 4.1 is postponed. It was eating up necessary time. More testing showed driver could not be probed again once removed. More files need to be patched.
2. vring's physical address in driver and that written to pru's memory are slightly different. Will have to resolve this issue asap so that messaging passing begins successfully.
Next Week
1.Try to finish vrings and begin writing example codes.
Week 6 Progress
08/19/2015 at 05:34 • 0 commentsDevelopments:
1. This week was dedicated to getting the driver run on latest kernel. pruss remoteproc driver now successfully compiles and runs on 4.1.1. Patches for kernel source will be up by tonight.
Issues faced:
1. Compiling a new kernel for beaglebone black and preparing a SD card for it is one mammoth task for someone doing it for the first time. I'll write a blog post on that on my hackaday project page later.2. Debugging several lines of kernel code which broke the driver when ported from 3.14 to 4.1.1
Next Week:
Get back to vrings. -
Week 5 Progress
07/01/2015 at 11:06 • 0 commentsDevelopments:
1. Fix major bug in driver which had gone unnoticed. Word offset given to read/write routines was buggy.
2. Improved user library. Previously pru cores booted when remoteproc driver was probed. Now user has pruss_boot ( "fw_path" , PRU0/PRU1 ) and pruss_shutdown(PRU0/PRU1) routines to independently handle power to each core.
3. Able to register virtual device with vrings using remoteproc.
4. Better example application in which ARM writes 2 values to pru memory -> interrupts pru 1 -> pru 1 adds 2 values and writes result to new location -> pru1 sends interrupt to ARM -> ARM validates result
Issues Faced:
1. Have lagged behind a bit while trying to understand the intricacies of vring communication. Need to cover up.
Next week:
1. Finish and wrap up vring based message passing from both ARM and PRU end.
Week 4 Progress
07/01/2015 at 10:42 • 0 commentsDevelopments:
1. Worked on user library code to allow individual PRU core boot and shutdown.
2. Wrote PRU firmware to receive interrupt from ARM and reply to ARM with another interrupt.
3. Make all three component work together : user program - driver - pru firmware.
4. Error handling in library.
5. Most importantly worked on repo to prepare it for tomorrow's evaluation. Prepared makefiles and added build procedure to Readme. git looks clean now.
Issues faced:
1. Circular queues already part of PRU-bridge. Need to discuss thoroughly with apaar regarding integration of these two to avoid code replication.
2. Exploring TI's progress on pru vring implementation taking time.
3. Cross-compiling 4.1 kernel is throwing errors. -
Week 3 Progress
07/01/2015 at 10:40 • 0 comments
Developments:
1. Send sysevents ( 0-63 ) from userspace to PRU throughr driver.
2. Configure sysevent->channel and channel->host map though firmware resource table. Very easy to use method.
3. Expose driver interrupts ( ie EVTOUT from PRU->ARM ) for userspace.
4. Interrupt handling in driver, while user is notified about interrupt. User can wait for specified interrupt from PRU (indefinitely or timeout).
5. User can give callback function along with wait. ( Ex. pruss_wait_for_interrupt ( EVTOUT1, mycallback ). mycallback is written by user
It receives the EVTOUT number as argument if the interrupt was successfully received.
Issues:
1. poll function was posing trouble. It requires a dummy read on the file descriptor before polling to work correctly.
2.Considerable amount of time goes in to find the best possible way to implement something which agrees to driver coding practices. Lots of resources scattered over internet. Collecting all important links along the way. Will write a blog post on issues faced and how they were resolved.
3. Some time to figure out resource tables of PRU firmware.
Next Week:
1. Complete work on DDR memory circular buffer.
2. Allow for custom modules to plug into remoteproc (so that advanced PRU users can use low level functions provided by pruss_remoteproc to utilize PRU more effectively as compared to user land implementation. This might take some time. -
Week 2 Progress
06/10/2015 at 12:06 • 0 commentsDevelopments:
1. Exposed appropriate sysfs attributes for data length,offset,memory type and data buffer to userspace.
2. prussdrv like functions for reading and writing to DRAM0, DRAM1 and SHR-RAM work now, allowing
a maximum of 4kB data to be written in one call.
3. Tested writing 2D integer arrays to PRU mem and subsequent read. Example code on github.
4. Dynamically boot/shutdown PRU from userspace at any time using driver-device bind/unbind function.
Allows for rmmod pruss_remoteproc without --force option.
5. Able to provide custom sysevt->channel and channel->host mapping to 3.14 pruss_remoteproc driver
Issued faced:
1. Abandon python for userspace library. Realized python is not feasible for writing code which interacts with hardware which has extremely limited space.In python, mostly everything is an object. Even an integer is an object which pushes its size to 12 bytes ie 8bytes of unnecessary infomation. With a PAGE_SIZE of 4096 bytes which to be the size of a sysfs file, we cannot afford python. Yes, there would be workarounds using this language itself, but when time on the platter is less, C saves the day.
3. Had to decide whether to send data via sysfs or send down userspace pointer (to data buffer) to driver. Reading from sources advised against sending userspace pointers down to kernel. Hence former was chosen.For more info as to why sending pointers is a bad idea read this: http://www.makelinux.net/ldd3/chp-3-sect-7
4. A persistent segmentation fault which took significant time to debug. Was due to dereferencing a null pointer.
5. Writing to sysfs was triggering both show/store functions. Issue resolved through mentor discussion. [ use open( ),write ( ) etc
instead of fopen ( ) fwrite ( ). ]
Next Week:
1. Allow INTC mapping and configuration from userspace.
2. Ability to dynamically allocate larger circular buffers in DDR mem.
3. Extend userspace library to allow DDR read/write.
Code on github
Shubhangi Gupta
