Version 0.2.0 almost finished.
04/17/2016 at 20:54 • 0 commentsThe new version is almost ready. I changed a lot of fronted stuff. Some major bugs are fixed. Finally i also finished the MeshLab integration. The FabScanPi is now able to generate meshes of the point clouds. But that is not enough... you are able to generate textured meshes within the new version.
Here are some screenshots.
Object which was scanned.
Textured Mesh of the Scan.
Textured Scan of our famous FabScan Bear.
Now with MeshLab integration
03/14/2016 at 08:58 • 0 commentsDuring the last weekend i added MeshLab support to the FabScanPi Server. MeshLab can be used for meshing and postprocessing the pointcloud. It can be called within the FabScan Pi Frontend. Here are some pictures ...
Raw scanned point cloud
MeshLab post processing result.
A scan posted by a user in the FabScan google Group.
Draft for new FabScanPi enclosure
03/07/2016 at 13:19 • 3 commentsWe are working on a new FabScanPi enclosure. It is discussed at the FabScan google group.
Instructable : FabScanPi
02/22/2016 at 09:25 • 0 commentsJan created a nice Instructable for the FabScan Pi - Open Hardware 3D Laser scanner. He also made a new case design.
http://www.instructables.com/id/3D-Scanner-FabScan-Pi/
New Release v.0.1.13
02/22/2016 at 09:20 • 0 commentsA new software release is out:
- fixed issue #3 server hangs when laser not detected
- fixed issue #12 internet connection is no longer needed, added font-awsome fonts to www
- scanner does start even if serial or camera connection fails, a message is shown in frontend now
- fixed mjepeg connection error bug, stack trace is not longer shown in log
- fixed some bugs in FSCamera.py
- added new frontend with saturation slider
- added funtions to support camera saturation adjustment
- prepared multilingual support (en only until now)
https://github.com/mariolukas/FabScanPi-Server/releases/tag/v.0.1.13
FabScan Pi in MagPi Magazine
10/07/2015 at 19:05 • 0 commentsYou can find a nice article about the FabScan Pi project in the curren MagPi Magazine.
Here is the link to the online article:
https://www.raspberrypi.org/magpi/fabscan-pi-project-3d-scanning-for-all/
And here the PDF version of the Magazine:
Maker Faire Berlin
09/23/2015 at 07:32 • 0 commentsCome and visit our booth at Berlins first Maker Faire on 3th and 4th of October. You can find this project at the booth of "Freie Maker".
Chaos Communication Camp 2015
08/05/2015 at 08:45 • 0 commentsI will bring the new FabScan Pi 3D scanner to the CCC Camp. If you want to scan stuff, visit our village.
FabScan Pi Featured by Dremel
07/18/2015 at 11:56 • 0 commentsYesterday a new episode of Dremels Youtube show called "Hammertime" came out. They visited the FabLab Aachen and built a FabScan 3D Scanner.
FabScan Pi Software Release soon.
07/18/2015 at 11:54 • 0 commentsLast week i finished the work on the new FabScan Pi Software. I will build some Debian Packages this weekend and do a release until the beginning of next week.
