You don't wanna get hooked on this stuff!
04/28/2014 at 21:18 • 0 commentsHey we finally finished the Jack Dispenser!
We first had to finish the painting and add the final paint layer to give it the perfect touch. Next was to glue the plama ball circuit into the water sprayer, we wanted it to be the closer from the plasma ball to ensure the cable's contact in it. We then had to solder all of the speakers cables (4 one-end jack connector) the auxiliary input (one 3.5mm to 6.35mm jack). We used a jack to RCA adapter to plug the Raspberry Pi straight into the amplifier.
After assembling the 3-floor structure, well... We had to disassemble it because the leadscrews were too tall. So, after re-cutting the leadscrews and re-assembling the inner structure we were ready for the big final : put the plasma ball on the top the the Jack Dispenser and turn it on with some kickass guitar sounds. The results can be seen on the videos in the details of our project. Check it out!![]()
It is complete ! Well...
...Not exactly. We still have to improve some of the features to enhance the user's experience a bit more as it is quite essential. So even if it is tagged complete as the Jack Dispenser is now fully funtionnal, things like the WebUI still need to be improved, for example we're actually thinking of a replacement for lighttpd in order not to go through the whole server configuration and its use with PHP. We'd like to find a server that could be directly implemented in the package, so if you think of one that could fit our need, tell us in the commentary section!
What about your amplifier ?
Nothing yet. The plane must have gone lost somewhere in the bermuda triangle as we still have no news or even the ability to track the package. We somehow hope to receive it in the week or even the next one but we can't know. We'll update the pictures and cabling of the amplifier as soon as we receive it so stay tuned for some more cool stuff! For the moment, all we have is an amplifier we borrowed to a friend.
What your project could be used for ?
We tried to make generic scripts that would be reusable in others projects. We already have some ideas on how to re-use our whc-switch in others projects like the "HackerBoy" which would basically be a Hacked GameBoy containing a rasberry Pi. It would of course be powered by a little battery. The HackerBoy would actually use the screen and buttons to control the Rasberry Pi and use command line softwares and utility. As it would be a connected GameBoy, it should be able to make a lots of cool things like our Jack Dispenser.
minidlna-autoconfig is now on the AUR and accessible by everyone. We think that some people are fighting to get a simple but working configuration for minidlna and we are distributing these scripts just for them. We will add an entry to the ArchLinux Wiki to make it more popular and see if it can help people.
We also created the "Share Your Profits License" you should take a look on, it is a just-borned license, but it'll be finalized soon and everything we coded for the Jack Dispenser is now distributed under it!
The Jack Dispenser, version 2 ?
After seeing the announcement of the new form-factor for the Raspberry Pi, we had some thoughts about making a new version of the Jack-dispenser, with custom PCB and fully integrated 4 channel audio amplifier (maybe a custom amplifier with some STA540 or alike amplifier). We will probably try to do a better structure, perhaps using fiberglass.
Briefly, we will try to keep this project alive ! Stay tuned for others updates and demonstrations !
001100010010011110100001101101110011
04/24/2014 at 22:23 • 0 commentsHere we are for our third update since the begining of this project and we are actually about to tag it complete.
The end is near!
This week and the last one's work was a lot about coding and building the structure.
Like we planned, we bought some hinges at the local store and we used our Dremel to drill some place for one hinge that is discretly located on the upper outside border of the basins. One hinge seems enough for us but we had to find a way to keep it opened properly and so we chose the good old-fashion chains to keep it open at certain angle without falling.
Discrete hinge
Still with the Dremel, we drilled some holes in the water sprayer for the female jacks and cut the bottom of it so we could pass cables from the water sprayer to the basins. We also drilled a slot into the water sprayer in order to install the circuit from the plasma ball into it and have an access to the on/off switch. We will install it definitly when the Jack Dispenser will be painted.
As stated above, we also had to start painting the Jack Dispenser so it would be the same color as the device in the Futurama's episode, unfortunatly we weren't able to find the same colour and so went for the Bordeau painting spray. The entire painting spray was actually enough to correctly paint the entire structure (note that the basins received three successive layers of paint minimum as much as most of the other parts that needed to be painted).
GPIO & WebUI
We spent a lot of time on the software side, trying to figure out a simple way to enhance user experience without having to add a display and/or a keyboard. As described in our second Project Log, we made a script that reads the input from a physical switch and switches between hotspot and client mode depending on the switch state. The script, nammed whc-switch, is also able to start/stop/restart systemd services depending on the switch state. You are able to customize this by using the configuration file which is shipped with whc-switch. Actually, we needed it for gmrender-resurrect which doesn't react really well when changing network configuration.
More than that we have started working on a WebUI you can use to configure/add/remove netctl profiles as you wish and display the profiles specs. The WebUI is designed to receive only one connection at a time so you wouldn't actually be able to edit profiles from two computers causing troubles to happen when saving the files from two locations. It is more secure even if passwords from the netctl profiles are displayed in clear text (we will be working on encryption after the contest is finished).
We felt that we also needed a way to communicate the wifi state to the user. We chose the simplest way: leds. One blue for the wifi state and one red that will light up if a problem occurs. The blue led will blink when the wifi is in hotspot mode (host mode) and will stay on if the wifi is in client mode.
How to connect the switch and the leds on the Raspberry Pi (B Rev2)
As we showed you on the last update, we thought of a little structure for the power supply, the Rasberry Pi and the motorcycle amplifier. We chose to use the rodolpheh's CNC to cut and drill the plates in MDF and now have our internal structure almost ready (we just need the amplifier to make the last floor).
A rip in the space-time continuum lost our amplifier
We're still waiting for the motorcycle amplifier. We bought it one month ago from DealExtreme and have no news since the fourth of April. We don't think we will get it before the end of the contest but we still want to tag it as complete because nothing have to be made on the amplifier except plugging cables, which is not a hard task. We rely on the understanding of the Hackaday's team for accepting our project as complete.
We're sorry we can't present you the final version of the Jack Dispenser but we have another amplifier we'll use for the demo just to show you it's fully functionnal but it doesn't fit our specs. We will also show you how the whc-switch works.
Stay tuned for our last Update Log on saturday !
"I'm gonna drink til I reboot!"
04/07/2014 at 20:04 • 0 comments"We're back baby !" for our second update after two weeks since the last project log.
Things are real fine, we actually received most of the components we needed and were able to get to work on both hardware and software sides and so we were able to code the things we needed to configure minidlna quite easily and post a build instruction about it.
"1.21 gigawatts of electricity !" [Dr. Emmett L. Brown]
Last week, we took a day to go to the local store in order to prepare a good power cable for the power supply. We used a flat plug with a little hook to unplug it and a foot-triggered switch. This won't looks really futuristic but hey! if you have seen "THX1138", you know that white IS futuristic! Quickly, we got into testing and adjust the power supply.![]()
Adjusting the power supply
THX1138 style cable
The Cable guys
As the jack dispenser needs jack connectors we also started the soldering part. So now our 5 female jacks are ready to be plugged on the little amp we are about to receive. We soldered one of our ø6,5mm female jack to ø3,5mm male jack for auxiliary sound input using an old audio cable for stereo. The last four of them are soldered on mono audio cable. Since the female jacks are stereo, we needed to solder it in a way it would act as a mono. We came up with this cabling:![]()
Mono cabling
Stereo cabling
The cables we made
The cables were tested with an adapter and plugged to a laptop. It worked perfectly as we planned.Thinking gave us a headache
The plasma ball has also been disassembled to see how it could fit in the whole structure. We also tried, with success, to add a longer wire to the plasma ball for when we will fit it in the Jack Dispenser. There is some kind of metal scrap inside the plasma ball and the wire should touch it in order to make a good electrode.![]()
For the same concerns we made a 3D model of a tiny 3 floor wooden structure that will be placed in the lower part of the jack dispenser. The advantage of this little structure is that it will ballast the object so we can easily open it without worrying it would fall. Opening the jack dispenser will probably be done with hinges, by leaning the upper part like you would do with a treasure chest. The floors will be held with leadscrews and nuts. It is as simple as it could be and we should be able to get it in or out easily for maintenance.
Here is a quick model of our structure. We will probably update it as soon as it evolves.![]()
Getting the sound
Besides all the functions we can find in the amplifier (SD card, USB, aux input, FM/AM etc...), we felt like we needed a more modern way to play our music. We found a USB dongle that was lost on a previous project and decided to search a way to stream music from any devices without dragging kilometers of cables or having to install complex software.
After a few experiments with different media streaming systems, we choose to get our hand on the DLNA protocol which is widely used by a lot of (not so) smart TV and media devices. The DLNA protocol (in a media streaming context, forget about DLNA printers), allows a device to be one of the three kinds of these devices:- DLNA Server: this device can stream media over the network
- DLNA Renderer: this device render the media (plays sound on headphones or video on screen)
- DLNA Controller: this device act as a controller, it can tell from which server the renderer should get its stream and is able to pause/play it or make playlists
We came up with minidlna which is a common software you can find in any good Operating System. Minidlna acts as a DLNA Server. With it, you should be able to read media contained in an external hard disk or in the SD card of the Raspberry Pi, on a DLNA Renderer such as your TV or your cellphone.
In order to add DLNA rendering to our Jack Dispenser, we used gmrender-resurrect which is a not so easy to find software. Luckily, it was available in the Arch Linux AUR (user repository full of scripts to build packages). It works natively with Alsa and enables the user to send music to the Raspberry and hear it coming from the Jack Dispenser. All the rendering tests went actually so fine pierrep decided to use personnaly miniDLNA and a gmrender-resurrect to use his cellphone as a remote for all medias played on his computer. No lag happened to show up while any of the tests and use no we can now tell miniDLNA perfectly matched the intended software purposes of the project.
What do we plan ?
We had some though about adding a switch to the raspberry to enable a kind of hotspot connexion. This connexion will be useful in case there would be no WiFi available. The user will be able to connect onto our Jack Dispenser and stream the sound regardless the lack of connectivity as long as he stays around. More than that we though of creating a WebUI that will enable the user to control the WiFi hotspot and save SSID and password in order to autoconnect when a wifi network is detected and when the Raspberry isn't in hotspot mode.
After receiving the amplifier, we will start building the Jack Dispenser and try to make a quick demo of the basic fonctionning, how to open it et cetera. Don't miss it!
Note: we're trying to make this project as fast as we can but we can't be shipped faster than the delivery boy can run. Plus, we are working all day and have others activities beside making fun projects (pierrep is playing in a band, go listen to the (badly recorded) great songs on Soundcloud, next time you will here it, it will be on a Jack Dispenser!). Please stay tune for (not so) badass sound! -
"If jacking on'll make strangers think I'm cool, I'll do it!"
03/24/2014 at 17:35 • 0 commentsHello World, here's our first update, it's not a big and important one but it will allow us to present you the components we get and the thoughs we had on the design.
NOTE: all dimensions are in mm.
Buy online... And what ?
On a sunny sunday, between two naps, we bought the main components on Internet. We opted for a motorcycle amplifier with 4x20W output channels that will be the heart of our Jack Dispenser. We also bought two plasma balls (in case we would break one) that can be powered with USB. It's 80mm wide and won't be too power-hungry. After getting these components on the web, we have to wait for them to deliver so we will see how we will use them later. Stay tune !![]()
The motorcycle amplifier. 80W under the (tiny) hood.
The cute USB plasma ball
As we though of our project a little more, we encountered the first problem and one of the most important thing in our project : the design!
If it wasn't for the design the Jack Dispenser wouldn't look Sci-Fi enough to satisfy the Hack-A-Day team.
The first step for designing our project was to determine how it would be build. As seen later, our choice was to get common everyday-used objects that could be bought for a cheap price. But we had to choose what kind of objects could be used and their possible dimensions. At that point, it was obvious that we should get our hands on drawing it with the model we got on the Futurama's episode.
Drawing and scaling
First, we used Inkscape to draw a half-cutted view of the object on a semi-transparent screenshot we placed on the background. The drawing was made roughly, to get a basic idea of the shape.![]()
Using Inkscape to draw basic shapes
Next, using Qcad, we corrected the previous drawing and after struggling with Qcad, we finally were able to scale it using the only known dimension : the plasma ball which is 80mm wide. With some measures, we were able to make a list of everyday objects with a shape that would fit in our design with their dimensions.
Correcting and scaling with QcadShape Height Width (diameter) Plasma ball 80 80 Big bowl (x2) 60 200 Little bowl 50 80 Smaller bowl 50 75 Champagne flute ? 70 20 (bottom) ; 45 (end) These shapes were what we planned to find. Thankfully, the motorcycle amplifier is so tiny that it could fit in a big bowl 200mm wide. But we found others objects and shapes in the store :
Object Height Width (diameter) Basin (x2) 150 300 Water sprayer 150 140 Champagne flute 110 20 (bottom) ; 50 (end)
Crap hunters !
Since it's an Hack-A-Day contest we thought common objects once assembled would perfectly do the trick with a bit of work and decided to go where some of these can be found a really resonable price as we intended it to be quite a low cost object to replicate. Fortunatly we were lucky and hit the strike as all of the objects for the design could be found at a crap-junk yard called Babou. For 12,90€ we had it all! 2 simple basins of 300mmØ, a water sprayer (or whatever you use that for), and plastic champagne flutes (pack of 8).![]()
On top, from left to right: water sprayer, champagne flute ; on bottom : two basins
Back home we were able to assemble the very first crappy prototype in less than one minute.![]()
The crappy design prototype. Really close, isn't it ?
And next ?
Next ? We have to wait for the components to deliver and buy a few more components to build it perfectly. We will make updates as long as we build it, with pictures and details.
NOTE: We're aware that the device seen on Futurama does not fit the exact same dimensions. It's Matt Groening's fault, who's not aware of how a Jack Dispenser looks like in Y3K !
RodolpheH
