1Step 1
Solder wires to the modules so they can be programmed.
2Step 2
Connect the modules to the Raspberry Pi.
3Step 3
Setup the programming environment on the Raspberry.
4Step 4
Compile the code and download it to the modules.
5Step 5
Make a case or modify one to accommodate the transmitter.
Extra HW is a push button, a CR2032 battery holder, a resistor and a LED.
6Step 6
Connect the receiver to the car's alarm. Disconnect the alarm's receiver by cutting the PCB trace that connects it to the microcontroller.
Extra HW is a 3.3v regulator (or module) to connect it to the 12v.
7Step 7
Additional features: connect the receiver to the car's board computer to display low battery warnings.
Rui Rex
