Added some new boards
09/26/2015 at 00:47 • 0 commentsSOT223
SOT89
TO252 / DPAK
1206 and 1206W
Check out the GitHub repo.
Next Revision
07/07/2015 at 02:19 • 0 commentsBased on the units I received from DirtyPCBs, I narrowed several boards by 0.1" and made several silk screen modifications. I also dropped the version stamp from the file names and the board. I figured for boards this simple, the versioning was more of a PITA than it was worth.
First DirtyPCB Fab Received
06/15/2015 at 20:20 • 0 commentsReceived back my first fab of some of the boards from DirtyPCB. Looks like I have several silk screen issues to work.
Sorry for the lighting glare. My workbench is in a basement and in order to get a legible photo I have to put a light right beside the PCB.
Front:
Back:
Silk Issue & SOT23
06/09/2015 at 02:49 • 0 commentsFixed a silkscreen issue with QFN32-TQFP32 and added SOT23-3 - SOT23-6 board.
Panel Design Help?
05/28/2015 at 02:31 • 3 commentsIf you have some experience with Eagle and would be willing to spend some time putting together 5cm x 5cm and 10cm x 10cm panel BRD files for DirtyPCB fabrication, I would much appreciate the help. Drop me a comment here.
Renamed QFN-28 Boards
05/28/2015 at 02:21 • 0 commentsMy current QFN-28 boards are designed with 3mm QFN-28 chips. If you have a QFN-28 that is a different size, it will not work with these boards. I have renamed the files to include this info.
Kevin Neubauer
