In this project I use my selfmade CNC router to produce a plywood frame for my next quadcopter project. First of all I will use a commercial flight control. In the next step I want to develope a custom made STM32 based flight control for the copter. We will see...
After the fail of the last frame I decided to make a new, stronger design. Maybe it looks not as nice as the old design. But it should be much stronger and more reliable.
OK. The very firstflight wasa terrificletdown.The copter crashedjustfromhalf a meterheight. The 4mm plywood is obviously not the right choice for this project...
To have enough power on the motors it is necessary to distribute the accu power in a proper way. For this purpose I have milled a power distribution board on my CNC router (of course ;-) from a double sided FR4 board...
The top layer is for "+" and the bottom layer for "-"
OK. Doday I have mounted the brushless motors and checked the fitting of the accu and the flight controller. The next step is to mill a power distribution board!
Very cool! Do you plan to protect/waterproof the frame? You could make something really unique (and awesome looking) with some stain and a bit of spar varnish..
Any chance of getting the toolpath files or cad files for this? Excellent looking project!
