xbmc on Raspbian
03/25/2014 at 23:42 • 0 commentsso after having to learn a lot about how to use VI and how to edit and save files using VI i was able to fallow this guide up to the part about installing xbmc
http://npapak.blogspot.com/2013/04/how-to-install-raspbian-and-autostart.html
I am at the step of
The user which you're going to run XBMC as needs to be a member of the following groups:
will be compelling the other steps tomorrow
I have had never used VI before sense i am a still very new to linux if you want to learn more about VI here are the guides i used
http://www.lagmonster.org/docs/vi.html
https://www.washington.edu/computing/unix/vi.html
Screenly Open Source Edition
03/25/2014 at 20:11 • 0 commentsmy next test in the Rasberry pi slide show is this build of Raspbain
I am testing the open sources version but once again this means we need to have a network connection in the room i like this one the best so far because i can add more images and can likely build a scripted to update the images but will need to wait until im sure that the network is up and running in the room. I am using the open sources version because I don't want to have to use the web version
http://www.screenlyapp.com/ose.html
xbmc
03/25/2014 at 19:37 • 0 commentsThe simplest answer to this project is to use xbmc or openelec but i really wanted to try something with more of a Raspbain
type layout because it has much more that can be loaded for future projects so after trying xbmc i decide to install XBMC to Raspbain using this guided but have had no lock
Digital sign
03/25/2014 at 19:33 • 0 commentsNext i found this build of Raspbain that is a digital sign that i really though would do the the trick. however there is both a paid version and a free version and the free version is very limited in what it can do so this is also a no go
http://www.binaryemotions.com/raspberry-digital-signage/faq.html
Hatterofthewaste
