Retropie with a 2.2" LCD screen
Back to overview
Play your SNES or Genesis game on a 2.2" LCD screen
egyfikyjet wrote 05/31/2018 at 16:12 point
does not work, screen just shows white and that cat command gives a strange "device is full" please help
Fernando wrote 08/14/2016 at 11:38 point
I was not able to get fbcp loaded on startup by adding "/home/pi/rbi-fbcp/build/fbcp &". It seems that rc.local would simply omit to launch fbcp, any lines before and after the launch command would execute well... I guess it is something related to login.
I finally got it running by launching fbcp from "/usr/bin/emulationstation". I don't know i this is the right way to do it but seems to work for me.
Cheers
ulf.anso wrote 07/07/2016 at 07:46 point
Very cool and awesome project.
For booting line (Step 6), I had to put the lines into .bashrc, because otherwise it did not work.
But I have an issue, where my FPS is low, the screen loads after every 3 seconds or so. How could that be fixed that it would be smooth?
Grégory Paul wrote 07/07/2016 at 16:58 point
Maybe try to change the speed parameter. 48000000 is for 48 Mhz, perhaps your screen can’t handle it. Try a lower value (32 Mhz or 16).
autopista wrote 12/23/2015 at 01:25 point
You can upload a video of how to do?
It would be very interesting,
thanks for your work
Grégory Paul wrote 10/17/2015 at 19:54 point
I added a line to path where I build rpi-fbcp at the end of /etc/rc.local.
jdj333 wrote 10/17/2015 at 17:19 point
(step 5) I was able to build the rpi-fbcp. But how do I set it to launch at boot?
Grégory Paul wrote 04/16/2016 at 17:17 point
You’ll need to add a line to /etc/rc.local file : sudo nano /etc/rc.local
Then, go at the end of file (but before the exit 0) and add a line where to find fbcp :
