1Step 1
Known CAN Codes so far:
For CAN Codes please visit the Sources-Page.
2Step 2
Instruction Video:
3Step 3
Arduino Source Code:
//############################################################################################################## //Volkswagen CAN BUS Gaming //Test Sketch v3.0 //(C) by Leon Bataille 2015-2016 //Hackaday Project Page: https://hackaday.io/project/6288-volkswagen-can-bus-gaming //Sketch information #DO NOT REMOVE! String game = "VW Static v3.0"; String vendor = "Leon Bataille"; //END Sketch information //For individual setup scroll down to the section MAIN CONFIGURATION //############################################################################################################## //Libraries #include <mcp_can.h> //CAN Bus Shield Compatibility Library #include <SPI.h> //CAN Bus Shield SPI Pin Library #include <Servo.h> //Library for Controlling Servos #include <Wire.h> //Extension Library for measuring current #include <LiquidCrystal_I2C.h> //Libraries for controlling LC Displays #include <LCD.h> #include <LiquidCrystal.h> //Definition #define lo8(x) ((int)(x)&0xff) #define hi8(x) ((int)(x)>>8) //Variables (Dashboard LEDs) int high_beam = 13; int fog_beam = 12; int park_brake = 11; //Variables (VW Dashboard Adapter) int LEFT_INDICATOR = A0; int RIGHT_INDICATOR = A1; int PARKING_BREAK = A2; int FUEL_WARNING = A3; //Variables (Dashboard Functions) int turning_lights = 3; boolean turning_lights_blinking = true; int turning_lights_counter = 0; int temp_turning_lights = 0; boolean backlight = false; int oilpswitch = 8; int pack_counter = 0; boolean add_distance = false; int drive_mode = 0; int distance_multiplier = 2; boolean oil_pressure_simulation = true; boolean door_open = false; boolean clutch_control = false; int temp_clutch_control = 0; boolean check_lamp = false; int temp_check_lamp = 0; boolean trunklid_open = false; int temp_trunklid_open = 0; boolean battery_warning = false; int temp_battery_warning = 0; boolean keybattery_warning = false; int temp_keybattery_warning = 0; int lightmode = 0; boolean seat_belt = false; int temp_seat_belt = 0; int engine_control = 0; int temp_dpf_warning = 0; boolean dpf_warning = false; boolean light_fog = false; int temp_light_fog = 0; boolean light_highbeam = false; int temp_light_highbeam = 0; boolean signal_abs = false; boolean signal_offroad = false; boolean signal_handbrake = false; boolean signal_lowtirepressure = false; boolean signal_dieselpreheat = false; boolean signal_watertemp = false; int temp_signal_abs = 0; int temp_signal_offroad = 0; int temp_signal_handbrake = 0; int temp_signal_lowtirepressure = 0; int temp_signal_dieselpreheat = 0; int temp_signal_watertemp = 0; //Variables (Speed and RPM) int speed = 0; byte speedL = 0; byte speedH = 0; int rpm = 0; short tempRPM = 0; byte rpmL = 0; byte rpmH = 0; int distance_adder = 0; int distance_counter = 0; //Variables LCD LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Addr, En, Rw, Rs, d4, d5, d6, d7, backlightpin, polarity //Variables CAN BUS /* the cs pin of the version after v1.1 is default to D9 v0.9b and v1.0 is default D10 */ const int SPI_CS_PIN = 9; MCP_CAN CAN(SPI_CS_PIN); // Set CS pin //Setup Configuration void setup() { //Initialize LCD lcd.begin(16,2); lcd.backlight(); showLCD("VW Dashboard","by Leon Bataille"); delay(2000); showLCD("VW Dashboard","booting..."); //Define Dashboard LEDs as Outputs pinMode(high_beam, OUTPUT); pinMode(fog_beam, OUTPUT); pinMode(park_brake, OUTPUT); pinMode(oilpswitch, OUTPUT); //Visual Start Sequence on Dashboard digitalWrite(high_beam, HIGH); digitalWrite(fog_beam, HIGH); digitalWrite(park_brake, LOW); digitalWrite(PARKING_BREAK, HIGH); delay(500); // wait for a second digitalWrite(high_beam, LOW); digitalWrite(FUEL_WARNING, HIGH); digitalWrite(PARKING_BREAK, LOW); delay(500); digitalWrite(FUEL_WARNING, LOW); digitalWrite(LEFT_INDICATOR, HIGH); digitalWrite(RIGHT_INDICATOR, HIGH); digitalWrite(fog_beam, LOW); delay(500); digitalWrite(LEFT_INDICATOR, LOW); digitalWrite(RIGHT_INDICATOR, LOW); //Begin with Serial Connection Serial.begin(115200); //Show Sketch information on LCD showLCD(game,"by "+vendor); //Begin with CAN Bus Initialization START_INIT: if(CAN_OK == CAN.begin(CAN_500KBPS)) // init can bus : baudrate = 500k { Serial.println("CAN BUS Shield init ok!"); } else { Serial.println("CAN BUS Shield init fail"); Serial.println("Init CAN BUS Shield again"); delay(100); goto START_INIT; } } //Reload LC Display void showLCD(String line1,String line2) { lcd.clear(); lcd.setCursor(0, 0); lcd.print(line1); lcd.setCursor(0, 1); lcd.print(line2); } //Send CAN Command (short version) void CanSend(short address, byte a, byte b, byte c, byte d, byte e, byte f, byte g, byte h) { unsigned char DataToSend[8] = {a,b,c,d,e,f,g,h}; CAN.sendMsgBuf(address, 0, 8, DataToSend); } //fuel gauge (0-100%) void Fuel(int amount) { pinMode(2, INPUT); pinMode(3, INPUT); pinMode(4, INPUT); pinMode(5, INPUT); pinMode(6, INPUT); pinMode(7, INPUT); if (amount >= 90) { pinMode(2, OUTPUT); digitalWrite(2, LOW); return; } if (amount >= 75) { pinMode(3, OUTPUT); digitalWrite(3, LOW); return; } if (amount >= 50) { pinMode(4, OUTPUT); digitalWrite(4, LOW); return; } if (amount >= 25) { pinMode(5, OUTPUT); digitalWrite(5, LOW); return; } if (amount >= 10) { pinMode(6, OUTPUT); digitalWrite(6, LOW); return; } if (amount >= 0) { pinMode(7, OUTPUT); digitalWrite(7, LOW); return; } } //Loop void loop() { //############################################################################################################## //MAIN SETUP FOR OPERATION //Set constant speed and RPM to show on Dashboard speed = 0; //Set the speed in km/h rpm = 800; //Set the rev counter Fuel(30); //Set the fuel gauge in percent //Set Dashboard Functions backlight = true; //Turn the automatic dashboard backlight on or off turning_lights = 0; //Turning Lights: 0 = none, 1 = left, 2 = right, 3 = both turning_lights_blinking = false; //Choose the mode of the turning lights (blinking or just shining) add_distance = false; //Dashboard counts the kilometers (can't be undone) distance_multiplier = 2; //Sets the refresh rate of the odometer (Standard 2) signal_abs = false; //Shows ABS Signal on dashboard signal_offroad = false; //Simulates Offroad drive mode signal_handbrake = false; //Enables handbrake signal_lowtirepressure = false; //Simulates low tire pressure oil_pressure_simulation = true; //Set this to true if dashboard starts to beep door_open = false; //Simulate open doors clutch_control = false; //Displays the Message "Kupplung" (German for Clutch) on the dashboard's LCD check_lamp = false; //Show 'Check Lamp' Signal on dashboard. B00010000 = on, B00000 = off trunklid_open = false; //Simulate open trunk lid (Kofferraumklappe). B00100000 = open, B00000 = closed battery_warning = false; //Show Battery Warning. keybattery_warning = false; //Show message 'Key Battery Low' on Display. But just after first start of dashboard. light_fog = false; //Enable Fog Light light_highbeam = false; //Enable High Beam Light seat_belt = false; //Switch Seat Betl warning light. signal_dieselpreheat = false; //Simualtes Diesel Preheating signal_watertemp = false; //Simualtes high water temperature dpf_warning = false; //Shows the Diesel particle filter warning signal. //############################################################################################################## //Conversion Speed speed = speed / 0.0075; //KMH=1.12 MPH=0.62 //Conversion Low and High Bytes speedL = lo8(speed); speedH = hi8(speed); tempRPM = rpm*4; rpmL = lo8(tempRPM); rpmH = hi8(tempRPM); if (add_distance == true) { distance_adder = speed * distance_multiplier; distance_counter += distance_adder; if (distance_counter > distance_adder) { distance_counter = 0; } } if ( oil_pressure_simulation == true) { //Set Oil Pressure Switch if (rpm > 1500) { digitalWrite(oilpswitch, LOW); } else { digitalWrite(oilpswitch, HIGH); } } /*Send CAN BUS Data*/ //Immobilizer CanSend(0x3D0, 0, 0x80, 0, 0, 0, 0, 0, 0); //Engine on and ESP enabled CanSend(0xDA0, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Enable Cruise Control //CanSend(0x289, 0x00, B00000001, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Dashboard Functions //Turning Light blinking if (turning_lights_blinking == true) { if (turning_lights_counter == 15) { temp_turning_lights = turning_lights; turning_lights_counter = turning_lights_counter + 1; } if (turning_lights_counter == 30) { temp_turning_lights = 0; turning_lights_counter = 0; } else { turning_lights_counter = turning_lights_counter + 1; } } else { temp_turning_lights = turning_lights; } //Check main settings //DPF if (dpf_warning == true) temp_dpf_warning = B00000010; else temp_dpf_warning = B00000000; //Seat Belt if (seat_belt == true) temp_seat_belt = B00000100; else temp_seat_belt = B00000000; //Battery Warning if (battery_warning == true) temp_battery_warning = B10000000; else temp_battery_warning = B00000000; //Trunk Lid (Kofferraumklappe) if (trunklid_open == true) temp_trunklid_open = B00100000; else temp_trunklid_open = B00000000; //Check Lamp Signal if (check_lamp == true) temp_check_lamp = B00010000; else temp_check_lamp = B00000000; //Clutch Text on LCD if (clutch_control == true) temp_clutch_control = B00000001; else temp_clutch_control = B00000000; //Warning for low key battery if (keybattery_warning == true) temp_keybattery_warning = B10000000; else temp_keybattery_warning = B00000000; //Lightmode Selection (Fog Light and/or High Beam) if (light_highbeam == true) temp_light_highbeam = B01000000; else temp_light_highbeam = B00000000; if (light_fog == true) temp_light_fog = B00100000; else temp_light_fog = B00000000; lightmode = temp_light_highbeam + temp_light_fog; //Engine Options (Water Temperature, Diesel Preheater) if (signal_dieselpreheat == true) temp_signal_dieselpreheat = B00000010; else temp_signal_dieselpreheat = B00000000; if (signal_watertemp == true) temp_signal_watertemp = B00010000; else temp_signal_watertemp = B00000000; engine_control = temp_signal_dieselpreheat + temp_signal_watertemp; //Drivemode Selection (ABS, Offroad, Low Tire Pressure, handbrake) if (signal_abs == true) temp_signal_abs = B0001; else temp_signal_abs = B0000; if (signal_offroad == true) temp_signal_offroad = B0010; else temp_signal_offroad = B0000; if (signal_handbrake == true) temp_signal_handbrake = B0100; else temp_signal_handbrake = B0000; if (signal_lowtirepressure == true) temp_signal_lowtirepressure = B1000; else temp_signal_lowtirepressure = B0000; drive_mode = temp_signal_abs + temp_signal_offroad + temp_signal_handbrake + temp_signal_lowtirepressure; //Send CAN data every 200ms pack_counter++; if (pack_counter == 20) { //Turning Lights 2 CanSend(0x470, temp_battery_warning + temp_turning_lights, temp_trunklid_open + door_open, backlight, 0x00, temp_check_lamp + temp_clutch_control, temp_keybattery_warning, 0x00, lightmode); //Diesel engine CanSend(0x480, 0x00, engine_control, 0x00, 0x00, 0x00, temp_dpf_warning, 0x00, 0x00); ///Engine //CanSend(0x388, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Cruise Control //CanSend(0x289, 0x00, B00000101, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); pack_counter = 0; } //Motorspeed CanSend(0x320, 0x00, (speedL * 100), (speedH * 100), 0x00, 0x00, 0x00, 0x00, 0x00); //RPM CanSend(0x280, 0x49, 0x0E, rpmL, rpmH, 0x0E, 0x00, 0x1B, 0x0E); //Speed CanSend(0x5A0, 0xFF, speedL, speedH, drive_mode, 0x00, lo8(distance_counter), hi8(distance_counter), 0xad); //ABS CanSend(0x1A0, 0x18, speedL, speedH, 0x00, 0xfe, 0xfe, 0x00, 0xff); //Airbag CanSend(0x050, 0x00, 0x80, temp_seat_belt, 0x00, 0x00, 0x00, 0x00, 0x00); //Wait a time delay(20); }
Is there anothe WIKICAN site that is still active?
Hey Leon,
Great work !!!!
I am trying to do something similar that you have done. I am trying to build a test bench for different car cluster to test them. My question is do I really need the CAN-BUS Shield or can I just build a test using just arduino ?
Testing include: Check all the gages works fine and all the lights comes on when we power up the cluster.
Hi Leon,
you did a very good job!!
How did you managed to discover all the needed message, value and sequence to be activated (motor on before speed to be displayed) ??
you are an artist in reverse engineering!!
Hi @Stefy,
thank you! I tried it with brute force :)
Try all the time different CAN Codes in a do-while loop and notice when something happens.
But I also found out some great websites with lots of information on them.
But you also may have noticed that the speedometer still doesn't work perfectly well.
Hi Leon, could you please update your Wiring Diagram for us. I`m having a hard time connecting the 34 leads from the Polo Dash to your little Polo Shield.
Hi Jeroen!
The Wiring Diagrams are both the same, but mirrored :D.
The left diagram by Is0-Mick is the view when you look on the backside of the dashboard. The schematic diagram describes the pin assignments from the cable to the board. That's why they're different.
Please use the left one for orientation.
Hello, Thank you for sharing your code.
I try to copy your solution but there is a problem with speed indicator. When I put smaller value than 0x0C in 0x5A0 then it's ok but when I put bigger value the indicator (needle) for about 10 second keep the right position and go down.
Maybe You know what I'm doing wrong.
Hi @jajan, thank you for your comment!
I'm having the same issue and I'm working on it. This is because the dashboard is waiting for data on address 0x5A0 and on another address. But I didn't find out this address yet.
Thank you for replay.
I thought that the "another address" it might be a ABS. I tried to send different values on 0x1A0 but without success.
Hi Leon, any news on this ? I'm getting the exact same problem, I've tried to send data to the 0x1A0 & 0x320 IDs (as per http://www.wikican.uni-bayreuth.de/wikican/index.php?title=VW_Passat_B6 ) but to no avail ...
I'm using a cluster from a VW Passat B6, but it seems all the commands are the same with yours...
Any help would be hugely appreciated !
Thanks,
Dan
Hi Leon,
This is an awesome project! I am currently working on a similar task. I am using cluster from VW Up, but it seems to work fine. Except for this issue with the speed indicator. Is there any update on this?
Kind Regards!
