Assembly Version
05/01/2021 at 07:47 • 0 commentsNew assembly version of the PIC16F145X bootloader has been uploaded to github. Reduces the size to less than 0x800 words. The other microcontrollers will follow soon hopefully.
New Assembly Version
07/22/2020 at 07:10 • 2 commentsAbout 70% done writing a version for PIC16F145X in assembly. Will be much smaller in size! I've had a request to make it small enough (under 0x7DB words) so that the first user instruction (user program starts) falls within the first program memory page. This is a requirement so that Great Cow BASIC compiled firmware will work with it. Practically an impossible task written in C. Hopefully won't take too long... If it's easy enough, I might adapt the assembly code to work with the other processors too.
Code on GitHub
06/28/2020 at 11:59 • 0 commentsOpen sourced the project on GitHub.
Johnny
