Mega 7-segment clock
The aim is to build a large indoor 4 x 7-segment RGB display to use a lighting in the room and of coarse tel me the time. Ideal futures includes Bluetooth , alarm clock integration , automatic brightness etc
Each segment will have about 7 of the ws2812B leds because with a heatsink they have a radius of 1cm and a segment is planned to be 7.5cm long.
Diffusion of light: I plan to either sand the glass or to use a thin paper membrane like wax paper. The interior of each segment is to be covered with foil to reflect the light and mix intensities better
Blocking of light: Currently I have two choices in masking of the light , first isto get a black or reflective decal cut at a store. My second option is to print templates and to spraypaint the glass with them. With painting the glass i could add multiple layers of diffrent colors of paint to ensure little light leaks through. So I will for example paint a layer of white , then black and then white again. The first layer being to match in with the sanded opaque glass , the second to absorb as much light as possible and the third is to reflect light back to the segmenst inne part itself.
Physical dimensions : The sign is planned to be 1.5m long 0.5m high and 5cm deep. The main factor that influences depth is how fast the light of the leds diverge and how fast i can make them diverge.
Interface: The plan is to incorporate a bluetooth module and to send cmd via a cellphone. Ideally the clock should integrate with my phone such that it lights up when i use my phones light and flashes when i should wake up.
  • 200 × WS2812B adressable RGB LED
  • 1 × Bleutooth module
  • 1 × ldr sensor
  • 1 × PIC microcontroller
  • 1 × 1.m X 0.5m Pane of glass
View all 7 components
  • ESP32 test
    oorspronklikheid • 02/10/2018 at 15:48 • 0 comments
    So recently I got my hands on a few ESP32s. Actually I got one , blew it up in no time , ordered 2 more. I'm going to esp32 for this project. Using a pic is not worth the costs or hassle.
    Here is a test i did with the esp32. This is 1 of 42 segments I'm using to test with. Its amazing how smooth the animation  appears although its only 7 leds doing the work in this test.
  • Diffusers
    oorspronklikheid • 12/03/2015 at 05:22 • 0 comments
    I thought I would make a small update what I've learned about diffusers.
    Generally I found that the DIY advice for making a better diffuser is to add more semi-opaque material like paper or cloth. But the issue with this advice is that you lose a lot efficiency. You can easily half your power output doing so. This means you you need to double your light output which again means twice as many LED's and twice as much power. I found the answer to this dilemma from LCD screens. They have additional layers in the back light part. One of the layers is a lens that acts like a Fresnel lens but not with a single focal point , rather like an circular focal point or line like {lenticular diffusers}. This type of lens greatly increases how much the light is spread and also does not block as much light. According to the link i just linked it has an efficiency gain of 42% ! These lenses is however not very cheap for consumers. So I plan to try and make them myself and see how well i can replicate this affect.
  • Some initial segment testing
    oorspronklikheid • 10/20/2015 at 04:05 • 0 comments
    I've been quiet on this project for a while now. I started getting distracted when I could not get two WS2812b leds to talk to each other but yesterday night I decided to to do quick test of how well a segment will light up and I wanted to see how large an segment will be. Up until this point I only had printed a 1:2 scale segment ( its in the gallery) and I wanted to see how large a segment will be , turns out I wanted huge segment. In the image i put the segment more upright than what I plan it to be.
    To construct this segment above I started with a 1:2 scale segment and laid out some masking tape and doubling each length. I then roughly cut out some wax paper on it such that it goes past the masking tape lines. Then I added the black electrical tape to stick the wax paper down and provide some optical contrast. I then roughly placed an led behind the glass about 10cm away and took the photo below:
    In real life the light is much more even. I blame my cellphone camera for the bright white spot. To the eye only the upper tip is faded a bit. I reckon i need about 2 or maybe 3 leds to light up a segment evenly. This is good news because i plan to use about 7 leds on each segment. The total length of the a single segment is about 21cm meaning a whole digit will be close to 50cm.
  • LEDs x400
    oorspronklikheid • 07/28/2015 at 17:48 • 0 comments
    I just got my LEDs . They somehow managed to ship within 3 weeks which is quite amazing for where I live. I couldn't resist taking a couple of close up pictures with my USB microscope.
    Surprisingly i could actually make out some detail of the tiny die in the LED.
    Some gold wire shots , not too interesting
    Zoomed out a bit showing the form factor better. The metalic areas looks a bit dirty, I hope each the led functions though.
    Oh yeah , i might just die from soldering 6 x 400 contacts!
  • LEDs!
    oorspronklikheid • 07/06/2015 at 17:20 • 0 comments
    I've finally ordered the LEDs. I originally planned to get around 200, but decided to order 400 WS2812 LEDs instead! If the Chinese spec is anything to believe that's around 80W-120W of RGB fun for me. Now I only have to wait for them to arrive and hopes my patience does not run out.
  • Starting out
    oorspronklikheid • 06/22/2015 at 03:57 • 0 comments
    Nothing has been ordered yet. Will update as soon as I do.
View all 6 project logs
