1Step 1
Make a gypsum soil moisture sensor
Components needed for one sensor:
- 2 x stainless steel machine screws, 6 - 32 x 2
- 6 x stainless steel hex machine nuts, 6 - 32
- 1 x piece of window screen glass fiber mesh (5 x 10 cm)
- 1 x plastic spreader (1.5 x 2.75 cm), holes for screws 1.25 cm apart
- 1 x plastic top cover 3.5 cm diameter, holes for screws 1.25 cm apart
- gypsum powder (Plaster of Paris)
3Step 3
Links to gypsum sensor casting details:
The Vinduino Project-2: Making and Installing Gypsum Soil Moisture Sensors
Link to calibration details:
Reinier van der Lee
yes, all good now. thanks for the prompt fix.
OK, thanks for the feedback. I'll check all the links for "https".
What can I do? I use iPage as provider for years now.
Maybe a solution is to go to www.vanderleevineyard.com, then open blog, etc?
When I open a link on any hackaday project page, firefox complains about security issues. Then I simply remove the https prefix, hit return again, and firefox is happy. May kaspersky is detecting something similar?
kaspersky says most of the links are "bad"
Hi Gary, I changed the links. My (new) Mac automatically added "https" when copy/pase links, have removed all the s-es.
Please let me know if it's OK now.
