Wheels
09/04/2015 at 05:58 • 0 commentsThe last couple of thumb wheels have been printed.
Adding some weight
09/04/2015 at 05:57 • 0 commentsI've hollowed out the base and added lead.
Printed lid
07/29/2015 at 05:50 • 0 commentsA lid was printed, the fit was off as I'd got my tolerances reversed, a bit of scraping got it to size but I've used some blobs of silicone sealant to hold it in place. The print required a support structure and the top surface is not the best but it's good enough for my needs and I can always paint it if desired.
I also seemed to have misplaced (or forgot to print) two of the thumbwheels so I'll need to do a couple more of those.
Knocked over....
07/23/2015 at 18:18 • 0 commentsThe base is going to need a bit of a redesign, if you extend the lamp all the way out then it topples over. I plan to chop a hole in the side and fill with some lead. I can also use this to put a panel on for the power socket and switch.
LEDs soldered
07/16/2015 at 14:28 • 0 commentsThe soldering of the LEDs went well. Next up, fitting the head to the base and wiring the cabling.
LED Jig
07/09/2015 at 07:02 • 0 commentsA simple jig made by drilling through the head to form 3 holes in the block of wood. I then formed an LED in the head and bent the legs at the right level. The two nails were banged in to form a height gauge. I can now solder up the LEDs without having to do it in place risking burning the ABS head.
Magnifier Lamp - What next
07/08/2015 at 07:04 • 0 commentsNext steps are to fit the LEDs and wiring. I might add another coat of varnish to the base and there's some feet to be screwed on.
