Chain of five tiny7s and ESP8266
A project log for tiny7
small seven segment display for plugging on an ISP programming header of an Atmel Board or an Arduino
alexAlex 09/28/2015 at 16:013 Comments
The tiny7 does also work with the Arduino IDE and the ESP8266. And five digits do work well. And a supply voltage of only 3.3V is also working.
The library for writing chars is still very experimental - as you can see by the code used:
#include <tiny7.h>
#define S_SDO 12
#define S_CLK 14
#define S_LTH 16
tiny7 myTiny7;
void setup()
  myTiny7.begin(0, S_SDO, S_CLK, S_LTH);
  myTiny7.show(7,0);    // ptint 7
  myTiny7.show(20,0);   // print Y
  myTiny7.show(16,0);   // print n
  myTiny7.show(19,0);   // print i
  myTiny7.show(18,0);   // peint t
  delay(1000);
I will try to add a better way to show strings or larger numbers soon. I am thinking of something like: myTiny7.print("string").
[If you are interested: The ESP-Board used on the picture can be fined here: #ESP8266 (ESP-07/12) Dev Board ]
davedarko wrote 09/28/2015 at 18:22 point
does it work on the radio module as well? ;)
Alex wrote 09/28/2015 at 18:53 point
Well if I would program the radio module with the Arduino IDE this
should work. But so far I programmed the radio module with Atmel Studio
and there is no working library for tiny7 and Atmel Studio yet (But this
is on the to-do-list).
davedarko wrote 09/28/2015 at 19:09 point
I'm using the usbasp to program the module over the arduino IDE :) had to add some hardware files. Needs some work too
