- support for common anode or cathode displays (selectable via jumper
- mechanical stronger pads at the side (more copper)
- fully compatible and mixable with rev2 PCBs if using common cathode displays
A project log for tiny7
small seven segment display for plugging on an ISP programming header of an Atmel Board or an Arduino
