1Step 1
OpenOCD Tutorial
install deps
sudo apt-get install build-essential
sudo apt-get install autotools-dev autoconf automake libtool
sudo apt-get install texinfo libudev-dev libusb-1.0-0-dev libfox-1.6-dev
Download FTDI driver
http://www.intra2net.com/en/developer/libftdi/download.php tar xf libftdi1-1.2.tar.bz2HIDAPI
git clone git://github.com/signal11/hidapi.git ./bootstrap ./configure make sudo make installBuild and Install OpenOCD
git clone git://git.code.sf.net/p/openocd/code cd code ./bootstrap cd ../ mkdir ./openocd-build cd openocd-build ../code/configure --with-ftd2xx-linux-tardir=../libftdi1-1.2 --prefix=/opt/openocd --enable-jlink --enable-ftdi --enable-stlink --enable-ti-icdi --enable-ulink --enable-usb-blaster-2 --enable-cmsis-dap --enable-bcm2835gpio make make installUsage
Prepare extra OpenOCD cfg commandscreate file openocd.cfg with following contents:
Start OpenOCD server to Debug LPC11U35$_TARGETNAME configure -event gdb-attach { echo "Halting target" halt }
Flash and Debugsudo openocd -f interface/cmsis-dap.cfg -c "transport select swd" -f target/lpc11xx.cfg -f openocd.cfg- First, flash debug firmware on board
telnet localhost 4444 reset halt flash probe 0 flash write_image erase /home/yliu/projects/ib51822/IBDAP-FW/Firmware/IBDAP/Debug/IBDAP.bin 0x0 reset exit- Second, debug using the commands:
target remote localhost:3333 break IBDAP.c:103 monitor reset halt monitor reset init continuehttp://wiki.paparazziuav.org/wiki/DevGuide/GDB_OpenOCD_Debug
Breakpoint limits
gdbtui GUI debuggingset remote hardware-breakpoint-limit 4 set remote hardware-watchpoint-limit 2http://fun-tech.se/stm32/OpenOCD/gdb.php
OpenOCD nRF51822 using IBDAP
Launch OpenOCD
$ sudo openocd -f interface/cmsis-dap.cfg -c "transport select swd" -f target/nrf51.cfgnrf OpenOCD log
yliu@yliu-xbtu:~$ yliu@yliu-xbtu:~$ sudo openocd -f interface/cmsis-dap.cfg -c "transport select swd" -f target/nrf51.cfg [sudo] password for yliu: Open On-Chip Debugger 0.10.0-dev-00001-g70a14db (2015-06-23-16:35) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : only one transport option; autoselect 'swd' Warn : Transport "swd" was already selected swd cortex_m reset_config sysresetreq adapter speed: 1000 kHz Info : CMSIS-DAP: SWD Supported Info : CMSIS-DAP: JTAG Supported Info : CMSIS-DAP: Interface Initialised (SWD) Info : CMSIS-DAP: FW Version = 1.0 Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 0 nRESET = 1 Info : CMSIS-DAP: Interface ready Info : clock speed 1000 kHz Info : SWD IDCODE 0x0bb11477 Info : nrf51.cpu: hardware has 4 breakpoints, 2 watchpoints Info : accepting 'telnet' connection on tcp/4444yliu@yliu-xbtu:~$ telnet localhost 4444 Trying 127.0.0.1... Connected to localhost. Escape character is '^]'. Open On-Chip Debugger > reset halt target state: halted target halted due to debug-request, current mode: Thread xPSR: 0xc1000000 pc: 0x000006d0 msp: 0x000007c0 > flash probe 0 Unknown device (HWID 0x00000057) flash 'nrf51' found at 0x00000000<span class="redactor-invisible-space"></span>
Yunfeng
