Updated for Drone Sports World at Maker Faire 2016.
The rugged 450mm size frames from Game of Drones are a fun foray into a medium size quadcopter. Made from military-grade polymer alloys, these frames are deemed nearly indestructible.
Details
First time flying a quadcopter.
First quadcopter build.
Plan to keep this build simple for acrobatic flight (no gps etc.)
I participated in demos and combat Friday and Sunday at Maker Faire. I destroyed the 32 propellers I brought and about another 20 provided. My craft did not rank but I had a lot of fun in the arena with the other pilots.
My drone combat entry. The flight controller suspension would get dislodged by the battery shifting on impact.
I'll be at Maker Faire trying to keep my drone up during the combat events on Saturday and Sunday. Hopefully I have enough propellers for two days of crashing :|
How to calculate the lifting capacity, if motor / propeller is known... I ask, because im thinking about to build my own drone, but i got no idea about about the needed lifting capacity and how to chose the right propeller / motor combination
Did your Hiro Quadcopter drift during hovering? I just started on building one and so far it drifts to the side and back. I tried adjusting it with the trims on the transmitter but no results. Do you have any suggestions? I am using the KK2.15.
Yeah a lot of quads will drift a little. I don't like using trims on the controller but the KK has ACC trim adjustments for auto level (use those), first try adjusting the position of the battery, usually its weight related you want a good center of gravity. Make sure its leveled too and props all look good when starting up. If you are testing indoors it will also be unstable just because of the air currents.
Ok cool, thanks a lot for the help. I tried moving the battery around before but I'll try again. Then I'll look into the ACC trim adjustments in the KK. Again thanks for the help and reply. I'll let you know if I end up fixing the issue.
To add to Richard's comments, sometimes drift can occur if your motors are askew on the horizontal plane. The flight controller adjusts based on the assumption everything is 'square'. If one motor is experiencing issues like drag, damage, or calibration probs, this can do it too.
