Integration Test
07/26/2015 at 21:20 • 0 commentsFinaly i took the time to integrate the Copter Module with the Copter.
It is a bit "tight fit" the Landing gear is restricting a easy slide in and out... and the PCB gets loose to easy.. at least it is bound to the LiPo-Akku.
Overall I'm still statisfied with the outcome :)
Next idea is to allow tethered Flying ^^
It got made :-)
07/16/2015 at 17:45 • 6 commentsToday i received the Part :-)
It looks nearly exactly like the 3D model :) And at least the PCB and LiPo fits :)
The test to mount the module to the copter is still open bc. i left the copter at an other place...
But it at least already glows nicely :)
Step 1
07/09/2015 at 21:41 • 2 commentsToday I designsparked :)
At the top is the same interface as the camera Module.
Below in the "Big Cage" on top there is the place for a LiPo Battery, it should be secured in Place by the Noses.
At the Bottom there is some kind of Spring mechanism to snap in the PCB.
The Size is about 50,5 x 35,99 x 23,5 mm.
I'm curious.. is it possible to calculate the probable weight or Volume of the Model?
I'm trying to get the Model Laser Sintered :-)
First Flight
07/08/2015 at 21:22 • 0 commentsI'm sure it will work much better, when the module is attached to the copter.
BTW: does somebody know, where to get those tiny RC connectors?
Stefan-Xp
