ESP8266 Greenhouse monitor
A device that would measure air humidity, temperature, sun luminosity, air quality and soil moisture and transmit it over WiFI.
This will be a mini project aimed at getting to know the ESP8266 NodeMCU platform and programming it in lua. I will use what I learn in my Grow In Box project.
Jeff Taylor wrote 09/09/2016 at 15:39 • point
I'm curious what you are using to measure air quality?  I'm going to be building a project that otherwise has the same specs, but I'm building from a bare ESP-12F.  Ideally it would work from battery/solar and transmit data to a web server every 5 minutes.  This is part of a bigger long-term project to provide data to a Pi Zero controlling my sprinkler system to minimize water usage.
Domen wrote 09/09/2016 at 17:42 • point
Hi!
I will be using MQ-135 sensor. It it good for measuring CO2 if it stays in a clean environment. Datasheet: https://www.olimex.com/Products/Components/Sensors/SNS-MQ135/resources/SNS-MQ135.pdf
They're really cheap on ebay/ali but the problem is that the coil inside needs to heat itself which takes 5 minutes I think and drains a lot of power, which probably wouldn't work for you :( I think all CO2 sensors have a start up time
Jeff Taylor wrote 09/09/2016 at 19:55 • point
Wow, thanks for the link!  You are correct that this sensor wouldn't add anything for my own needs, but this looks like it would be a great thing to have inside the house to monitor conditions.  I might have to grab one just to play with it.
Jeff Taylor wrote 09/15/2016 at 19:07 • point
I'm thinking I will be starting my own project page shortly.  Mine obviously has some differences from your project, but also similarities.  This week I've managed to get a 0.96" OLED display hooked up (useful for debugging, but probably too much power drain for the final project), a DHT22 temperature/humidity sensor, and a soil moisture sensor.  I found a useful page for multiplexing the single ADC port, so tonight I'm going to try and also get a photoresistor added.  And I found a module for reading barometric pressure (BMP180) which could provide some interesting data.  The last step will be setting up a web page and having this module send data for recording in a database, then figuring out how to use the deep-sleep mode to get the most out of battery life.
So thanks for the inspiration!  It's a lot of fun playing with the various bits of hardware and software, and seeing everything come together.
Domen wrote 09/15/2016 at 19:22 • point
I'm glad I inspired you with such an empty page :D Good luck with your project!
I'm using this cheap I2C ADC (4 channel) converter
http://www.ebay.com/sch/i.html?_odkw=pCF8591+Analog+Digital+Wandler+Converter&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XpCF8591+.TRS0&_nkw=pCF8591+&_sacat=0
You could also use this I guess, but the first definitely has libraries written.
http://www.ebay.com/itm/T-16-Bit-I2c-4-Channel-Ads1115-Module-Adc-With-Pro-Gain-Amplifier-For-Arduino-S-/331930366974?hash=item4d489773fe:g:LBUAAOSwqfNXpYt~
I have also decided to use arduino for the programming, environment not nodeMCU's lua
George I Fomitchev wrote 08/15/2016 at 06:58 • point
and we can send this data to the server
AVR wrote 05/20/2016 at 00:57 • point
Neat project!!! Doing something similar with my SunLeaf + HydroPWNics project also using the ESP8266 for connectivity.
Kopiko wrote 05/19/2016 at 16:16 • point
ohh. so how do you operate the water valve? can you elaborate to me? i'm sorry i am really having a hard time dealing with this. i hope you can help me.
Kopiko wrote 05/13/2016 at 11:19 • point
hi can we discuss about this project?
here my email: zarifsonick@gmail.com
i really need your help about the greenhouse project.
Domen wrote 05/16/2016 at 20:41 • point
What kind of help? I haven't even done anything for this project yet, I only created this project page.
Kopiko wrote 05/18/2016 at 16:21 • point
do you have the coding for the receiver from esp8266 module? coding to operate the water pump when sensor detect the change in temperature or humidity.
Domen wrote 05/19/2016 at 14:32 • point
No, no code was written.
