This is a super simple circuit to control loads using a small amount of power from a microcontroller. With the use of 2 N-channel MOSFET's and 2 P-Channel MOSFET's it is possible to build a very simple H-Bridge driver. This allows you to control the Polarity/direction of a DC motor.
Check out the kickstarter project to get your MOSFET Breakout board today. I need your support!
Perfect match with the ESP8266!
