1Step 1
Choose the Type of feeder to build [Or buy a Feeder if you have a massive lake]
2Step 2
Chose the type of Control System to build:
-Vision is suited to well defined ponds less than 20mx20m using floating Food
-Temperature is suited to any size Pond with any type of food
3Step 3
Calculate the Feed-Rate of your Feeder
4Step 4
Input the details to your controller [via usb and computer at the moment]
And run some bench top test to check it works as expected
5Step 5
Place in situe and use the Dial to fine tune
6Step 6
Consider adding extra features to the controller, better timed feeding periods, read the waters ppm. Its all open source so you can add to this whatever you feel like.
7Step 7
Michael Ratcliffe
