Final bed print area is 270mm × 205mm × 140mm
There's a slight rattle on the X-axis that i want to sort out, it causes some minor printing artifacts whenever X-axis changes direction fast, but nothing serious. I will have to make a new part.
A project log for Printrbot Simple Metal - Bed upgrade
I need a larger print area in order to print a printer
