1Step 1
1) find 3 same voltage transformers
2Step 2
2) build the baseplate with connector
3Step 3
3) buy the components, prototype board, and solder it
4Step 4
4) make PID or increment/decrement regulator sketch
5Step 5
5) try it with adjustable transformer and lightbulb
6Step 6
6) install it into the alternator junction box, try it at idle up to full power, then do some measurements with startup surges from overvoltage-proof equipment and then use it.
7Step 7
optional) make many more functions into it.
Michael Skrepsky
