HOW TO USE IT ?
Twiz modules are the most universal tools for wearable technologies, applications are simply endless but here are a few examples :
- Media control: modulate sound effects or control a light show from performers’ motion
- Scientific studies: analyse a building/bridge vibrations, animal activities…
- 2/3D Software: motion capture to animate 3D model of object, human or virtual creature
- Games: control your favorite doom-like from your hand, or breakout
- Anything that a beacon or activity tracker does
- Home automation: control your room's light volume by spinning your candle:
HARDWARE
MPU9150, 9 axis IMU motion sensor:
3D accelerometer for linear accelerations, 3D gyroscope for rotational accelerations, 3D magnetometer for orientation reference
nRF51822, processor + connectivity:
32 bit ARM processor with low consumption optimization (Cortex-M0), BLE (Bluetooth Low Energy AKA Bluetooth smart/4.0)
Physical characteristics :
2.4 cm x 2.4 cm (< 1 inch), 1.1cm thick (< ½ inch), 4.6g (~7.6g w/ battery)
It started with usual dev boards such as teensy, IMU and radio modules:
...but we shrunk it:
SOFTWARE
- Madwick fusion: send Euler angles or Quaternions
- ifttt recipes with our python/kivy interface
- experimentation using swift, noble
- open source: software / firmware / hardware (schematics, gerbers, BOM, etc.)
Software architecture:
Cedric Honnet
Guillermo Herrera-Arcos
Arturo
Hunter Santana
Olda
Can you send some command to your board and execute it by the CPU? e.g. changing state of some output pins? Like the LED on the video?
