After watching Winston Moy flood his cnc with threaded inserts I thought that I wanted to do the same, so I worked on creating a job to do inserts.
Happy with the results I was able to make a trip to home depot and get some materials. With some MDF and threaded inserts I made a board that will overhang the small lip of the Shapeoko frame rails, allowing me the full cutting area as well as many clamping locations.
I haven't really used it much. But I also haven't made any clamps to use with it.
Emerica
