layouting mockup / makefu lamp build
04/17/2016 at 19:27 • 0 commentssuch a nice mockup
behind the scenes - routed cabling slots
manual rework (not getting it right on the cnc mill is a good opportunity to use the manual router)
so much win:
mounted on white painted wooden plates gives a completely different look from the first installation.
light tests and first installation
04/13/2016 at 21:51 • 0 commentssome tests before our first wifi controllable led lamp installation.
Better drilling with Festool ... and Nadka.
looking good - notice the breadboard glued to the ceiling ... with the esp and ams1117 (5.5 -> 3.3V) regulator.
cube electronics
04/12/2016 at 23:45 • 0 commentsws2812b on pcb for hassle free soldering.
4 pin connectors for +- 5V, signal and signal loop through if necessary for some setup.
Connectors should be protected against polarity reversal- otherwise I will always short sth.![]()
helper (soldering) fairy
esp8266 breadboard test
all the glue
04/08/2016 at 11:49 • 0 commentsAcrifix (applied with a q-tip) works really good gluing the notched pieces.
Hot glue if you want to get it open ever again (here: top for access).
Gluing tool (perpendicularity)
some more gluing
first harvest:
lasercut the acrylic
04/06/2016 at 20:37 • 0 commentsFirst you have to design the lamp - in our case square boxes. Boxmaker to the rescue - or at least to jump start the notched boxes.
Some draft of one of the final lamps.
Then off to buy some acrylic...
... and put it in your hackerspaces' lasercutter (far cheaper than having the acrylic guy do it).
good material planning:
finding the right acrylic
04/05/2016 at 20:49 • 0 commentswe went to a local acrylic shop and asked for samples we liked without illumination.
then the selection followed
![pyramide gives a really nice effect - is a hackers favourite (as 3D cube)]()
project start
04/04/2016 at 23:15 • 0 comments
Christian Stöveken
