LPS Mini
Back to overview
Arduino compatible indoor navigation system with small form factor.
Göran Nordahl wrote 07/28/2016 at 06:29 • point
We have reached a maximum of 328m outdoors: From 59°19'11.27”N, 18° 3'42.14”E (just outside my lab) to 59°19'9.00”N, 18° 3'21.91”E (ugly house). We could not get further due to the ugly house blocking our way. We had enough antenna height and free space along the way so the first Freznel zone was without any obstructions: https://en.m.wikipedia.org/wiki/Fresnel_zone. We used maximum output power, longest possible preamle and channel 5. It is also very important with proper decoupling, a good PCB layout and a stable power supply. For normal use there is most often obstacles in the way thus reducing the range. 100-200m is a more reasonable distance outdoors, depending on your environment. Indoor use is very dependant on the material in your walls and other objects acting as attenuators/reflectors. 30-50m should be no problem in an open environment. Inside a warehouse there will be areas with more or less completely blocked RF signal path, but that can be handled with more anchors in the ceiling.
leandro wrote 07/27/2016 at 20:24 • point
Hi. You could achieve the maximum range described by Decawave? Indoor 30-50meters and outdoor 200-300meters. Do you have conducted some test?
